By Leen15
#35345 Hi to all, i just replaced a 0.96 OLED with a 1.3'' OLED but this one uses SH1106 instead of SSD1306 so i cannot use standard adafruit library. :?
I found that i should use u8glib library but i cannot understand what is the compatible version for ESP8266 (i'm using a nodemcu) because if i try to download from arduino library manager the original u8glib library it tell me that the library doesn't work with the architecture of the esp8266.
Any help?
Thanks a lot :)
