By NailBuster
#35375 wondering how this works: I don't fully understand where/how everything is stored in flash on the esp models.
I have a working project in esp12e (nodemcu board) that has 4MB flash. I want to create a BIN file for someone that will just flash the BIN file to their esp (no source).
If I create a bin export in arduino the BIN file is about 300KB. I've setup project with 3MB spiffs. I store settings in SPIFFS root folder as well....
Now if someone has an esp01 or esp with only 2MB or 1MB flash. Can they flash the above BIN file? do I have to make different BIN files for different flash sizes?
Is it possible to update an esp without overwriting the SPIFF area(or is that the way it works already)? If I create an update BIN but want to keep the users' config files within their SPIFFs would that work?
By Mmiscool
#35383 I use a bat file to do this.
Place the bat file i the arduino directory that contains the exe file. Change the inn and out settings a the top of the bat file to point at your sketch and desired output directory.
Code: Select allset INN=C:\Users\user\Documents\GitHub\Basic\ESP8266Basic\ESP8266BASIC.ino
set OUT=C:\Users\user\Dropbox\MicroController\esp8266\ESP8266_BASIC_INTERPERTERv2\ESPBasic_Flash_Tool\Build
arduino_debug --verify --board esp8266:esp8266:generic:FlashSize=512K64,FlashMode=qio,CpuFrequency=160 --verbose --preserve-temp-files --pref build.path="%OUT%\512k" "%INN%"
arduino_debug --verify --board esp8266:esp8266:generic:FlashSize=1M512,FlashMode=qio,CpuFrequency=160 --verbose --preserve-temp-files --pref build.path="%OUT%\1M" "%INN%"
arduino_debug --verify --board esp8266:esp8266:generic:FlashSize=2M,FlashMode=qio,CpuFrequency=160 --verbose --preserve-temp-files --pref build.path="%OUT%\2M" "%INN%"
arduino_debug --verify --board esp8266:esp8266:generic:FlashSize=4M3M,FlashMode=qio,CpuFrequency=160 --verbose --preserve-temp-files --pref build.path="%OUT%\4M" "%INN%"
By Mmiscool
#35397 Yes. it only create the firmware. It will not overwrite the spiffs.
I use this as part of the process to make the ESP8266 Basic flasher.
