By PyB
#35453 Hi,
I have a pretty weird UDP issue.
My setup is as follows :
- ESP8266 as SoftAP and UDP client
- ESP8266 sending an UDP broadcast packet every 2s.
- Android application connected as Wi-Fi Station and acting as an UDP Server
I'm able to sniff all the UDP packets in the air using another PC running wireshark and clearly see them on a regular 2s frequency.
On my Android app, I only receive packets once in a while in a kind of weird random fashion (I know UDP is not guaranteed - but doing tests in 'clean' air). I know my android application works as I have tested it with some other UDP clients.
I also have an older setup running the same Arduino software but using a Wi-Fi router and an W5100 ethernet controller (just changing from WiFiUdp to EthernetUDP). I don't have the issue with that setup.
I'm running out of ideas of what can be the root cause of this....
Below my code snippet, if anyone would see something wrong :
#include <WiFiUdp.h>
const char* ssid = "PyRC Timing";
WiFiUDP udp;
IPAddress   broadcastAddress(255,255,255, 255);
unsigned char udpBuffer[10];
long cnt = 0;
  pinMode(16, OUTPUT);
  Serial.begin(921000);
  while (!Serial);
  // Connect to WiFi network
  Serial.println("Setting up SoftAP");
  Serial.setDebugOutput(false);
  WiFi.mode(WIFI_AP);
  WiFi.softAP(ssid);
  IPAddress softAPIP = WiFi.softAPIP();
  Serial.print("IP address: ");
  Serial.println(softAPIP);
  udp.begin(4445);
    digitalWrite(16, HIGH);
    delay(1000);
     int volt = 500;
     long timeStamp = millis();
    udpBuffer[0] = (byte) (volt & 0xFF);
    udpBuffer[1] = (byte)((volt >> 8) & 0xFF);
    udpBuffer[2] = '-';
    udpBuffer[6] = (byte) (timeStamp & 0xFF);
    udpBuffer[5] = (byte)((timeStamp >> 8) & 0xFF);
    udpBuffer[4] = (byte)((timeStamp >> 16) & 0xFF);
    udpBuffer[3] = (byte)((timeStamp >> 24) & 0xFF);
    udpBuffer[7] = ';';
   udp.beginPacket(broadcastAddress, 4445);
   udp.write(udpBuffer, 8);
   udp.endPacket();
   Serial.print("Sent packet : ");
   Serial.println(cnt++);
 digitalWrite(16, LOW);
 delay(1000);
