By wiwo
#35648 Hi,
I'm trying to read some data from simple web page (https://pure-caverns-1350.herokuapp.com/stan)
It should respond with "0" or "1" (later I would like to turn output high or low regarding to this, but later...)
I have a problem with this code:
Code: Select all/*
const char* ssid     = "WiwoNET";
const char* password = "123456";
const char* host = "pure-caverns-1350.herokuapp.com";
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
int value = 0;
  delay(5000);
  ++value;
  Serial.println(host);
  WiFiClient client;
  const int httpPort = 80;
  if (client.connect(host, httpPort)) {
    Serial.println("connection success");
  else {
  // We now create a URI for the request
  String url = "/stan";
  Serial.println(url);
  client.print("GET " + url + " HTTP/1.1\r\n" +
              "Host: " + host +"\r\n");
  delay(10);
  Serial.println("Informacja zwrotna:");
  while(client.available()){
    Serial.print(line);
In serial monitor I have only:
Code: Select allConnecting to WiwoNET
WiFi connected
IP address:
192.168.0.111
connecting to pure-caverns-1350.herokuapp.com
connection success
Requesting URL: /stan
Informacja zwrotna:
closing connection
But what is weird I don't see anything in heroku's log...
I tested it with postman and get request works fine when I'm not using ESP-01
Where should I look for problem?
Thank you in advance for any kind of help!
By torntrousers
#35702 Could it be the old "delay(10);" after the client.print problem? Try increasing 10 to a few hundred or better still do this.
Really we should get the WiFiClient example that comes with the IDE changed as so many people copy that and then hit this problem.
