I have an odd problem ... most likely something goofy I am missing....
I have an ESP-01 with 1M.... I am able to flash it (with Arduino of course) fine... and directly after my code is flashed to it, it starts running without problem.
If I cut power to the ESP-01, the code does not run when power is re-applied......
Here is the code...... like I said... this runs fine directly after flashing it... but then acts like it was never loaded
#include <NeoPixelBus.h>
#define pixelCount 10
NeoPixelBus strip = NeoPixelBus(pixelCount, 2);
uint8_t rainbow[142];
float brightness = 0.5;
void setup()
pinMode(2, OUTPUT);
strip.Begin();
strip.Show();
createRainbow();
void loop()
int pos = 0;
while (pos < 141)
for (int i = pixelCount - 1; i > 0; i--)
strip.SetPixelColor(i, strip.GetPixelColor(i - 1));
strip.SetPixelColor(0, RgbColor(rainbow[pos] * brightness, rainbow[pos + 1] * brightness, rainbow[pos + 2] * brightness));
strip.Show();
pos += 3;
delay(50);
void createRainbow()
uint8_t redValue = 128;
uint8_t greenValue = 16;
uint8_t blueValue = 16;
int step = 1;
int pos = 0;
while (step < 7)
rainbow[pos] = redValue;
rainbow[pos + 1] = greenValue;
rainbow[pos + 2] = blueValue;
pos += 3;
switch (step)
case 1:
if (blueValue < 112) blueValue += 16;
else { blueValue = 128; step++; }
break;
case 2:
if (redValue > 0) redValue -= 16;
else { redValue = 16; step++; }
break;
case 3:
if (greenValue < 112) greenValue += 16;
else { greenValue = 128; step++; }
break;
case 4:
if (blueValue > 0) blueValue -= 16;
else { blueValue = 16; step++; }
break;
case 5:
if (redValue < 112) redValue += 16;
else { redValue = 128; step++; }
break;
case 6:
if (greenValue > 0) greenValue -= 16;
else step++;
break;
