By Falesh
#38228 I have got my NodeMCU working well now connecting to my local server. The one thing I still need to work out is the inconsistency of the time it takes to fetch a page from the server. Mostly it takes 5ms but sometimes it spikes up to anything between 50ms or 150ms and very occasionally 3600ms.
I put a load over various sized capacitors on the power line so that shouldn't be causing the issue. Is there a way to add a timeout to client.connect() so if it takes longer then 20ms it stops and retries the connection? For my application to work I need it to consistently take less then 90ms per request.
char ssid[] = "virginmedia54841";
char pass[] = "ljksdfli30";
const char* host = "192.168.0.27";
IPAddress server(192,168,0,27);
WiFiClient client;
  delay(100);
  Serial.println(ssid);
  WiFi.begin(ssid, pass);
    Serial.print(".");
  Serial.println("Connected to wifi");
  unsigned long testStartTime = millis();
  if (client.connect(server, 80)) {
    client.print(String("GET ") + "/index.php HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "User-Agent: ArduinoWiFi/1.1" +
               "Connection: close\r\n\r\n");
    client.println();
  } else {
  Serial.println(millis() - testStartTime);
  client.stop();
  delay(100);
By WereCatf
#38233 For one, are you sure the issue doesn't lie with the server and/or your local network? Can any other device using 2.4GHz WIFI get consistent <90ms replies from your server?
Secondly, it's a bad idea to design the sketch to rely on such strict timings over WIFI since WIFI is always subject to interference.
Thirdly, I do not know if running the sketch as both an AP and a STA simultaneously can affect such things, but you could test adding a
Code: Select allWiFi.mode(WIFI_STA);
before bringing WIFI up to set it strictly as a STA and seeing if that changes anything.
By Falesh
#38295 Thanks for the reply. I set up another wireless router and tried it on that. The results were much more stable but I was still getting the odd rare 3.5 second delay.
It would still be very useful to be able to set the timeout/retries on client.connect() so I am able to do something else in the code if it takes too long. For instance I could keep getting data and filling up an external SRAM chip to act as a data buffer for 90ms then do the other stuff I have planned. However this wouldn't work if I have no way to break out of an abnormally long client.connect().
By WereCatf
#38304 Now that I look at your sketch, you're actually testing the delay of client.connect() + client.print() -- modify your sketch to check how long client.connect() takes, then a separate reading for client.print(), like e.g. follows:
WiFiClient client;
  delay(100);
    Serial.print(".");
    Serial.print("client.connect() millis: ");
    client.println();
    Serial.print("client.print() millis: ");
  } else {
  client.stop();
  delay(100);
Now you can see which part it actually is that takes so long and maybe we can then see if we can do anything about it, yes?
