I've seen some software timers, but i need a better performance..
I try to dim a LED-panel via transistor on one of GPIO-0/1/2, but i have ABSOLUTELY no ideas how to implement something like this via the IDE...
Explore... Chat... Share...
for (int i=0; i < 1024; i++){
analogWrite(2, i);
delay(1);
for (int i=1023; i > 0; i--){
analogWrite(2, i);
delay(1);
}It takes about 20-25 seconds for home assistant c[…]
