I'm using the NodeMCU with the basic http client example.
Connecting to an http server on my LAN works fine, but going out to the Internet (via a URL) returns -1.
Any suggestions?
Thanks!
Explore... Chat... Share...
* BasicHTTPClient.ino
* Created on: 24.05.2015
#include <Arduino.h>
#include <ESP8266WiFiMulti.h>
#define USE_SERIAL Serial
ESP8266WiFiMulti WiFiMulti;
USE_SERIAL.begin(115200);
// USE_SERIAL.setDebugOutput(true);
USE_SERIAL.println();
for(uint8_t t = 4; t > 0; t--) {
USE_SERIAL.printf("[SETUP] WAIT %d...\n", t);
USE_SERIAL.flush();
delay(1000);
WiFiMulti.addAP("SSID", "PASSWORD");
// wait for WiFi connection
if((WiFiMulti.run() == WL_CONNECTED)) {
HTTPClient http;
USE_SERIAL.print("[HTTP] begin...\n");
// configure traged server and url
//http.begin("192.168.1.12", 443, "/test.html", true, "7a 9c f4 db 40 d3 62 5a 6e 21 bc 5c cc 66 c8 3e a1 45 59 38"); //HTTPS
//http.begin("192.168.1.12", 80, "/test.html"); //HTTP
http.begin("http://api.coindesk.com/v1/bpi/currentprice.json");
USE_SERIAL.print("[HTTP] GET...\n");
// start connection and send HTTP header
int httpCode = http.GET();
if(httpCode) {
// HTTP header has been send and Server response header has been handled
USE_SERIAL.printf("[HTTP] GET... code: %d\n", httpCode);
// file found at server
if(httpCode == 200) {
USE_SERIAL.println(payload);
} else {
USE_SERIAL.print("[HTTP] GET... failed, no connection or no HTTP server\n");
delay(10000);
