I don't know why but I am now unable to change Access Point Name...
It did work a few months ago, but now I can't change it.
I have tried to reflash the ESP, but doesn't work
The code I am using is the AccessPoint example in the IDE :
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "ESPap";
const char *password = "thereisnospoon";
ESP8266WebServer server(80);
/* Just a little test message. Go to http://192.168.4.1 in a web browser
* connected to this access point to see it.
void handleRoot() {
server.send(200, "text/html", "<h1>You are connected</h1>");
delay(1000);
Serial.print("Configuring access point...");
/* You can remove the password parameter if you want the AP to be open. */
WiFi.softAP(ssid, password);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/", handleRoot);
server.begin();
server.handleClient();
}Same thing if I remove the password...
Do you have same behavior ?
Thank you
JP
