I have an ESP-201 attached to an external power supply and directly connect with a DHT22 on PIN 2. My software is very simple: (1) connecting the WLAN (2) read the DHT22 values (3) post them to my server (4) go to deep sleep (1) .. (2) ..
My project starts, connects the WLAN and reads the current values. After that it goes to deep sleep for a few seconds and restarts successful and establishs the WLAN connection, but the sensor values are NAN. If I restart the ESP8266 "hard", the first values reading from the sensor are valid again, but fails the second time after deep sleep. The procedure is repeatable.
Have you guys any ideas about that?
extern "C" {
#include "user_interface.h"
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
// Uncomment whatever type you're using!
//define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE, 15);
const char* ssid = "WLAN";
const char* password = "1234567890xyz";
const char* host = "192.168.180.12";
const char* thingspeak_key = "API_KEY";
void turnOff(int pin) {
pinMode(pin, OUTPUT);
digitalWrite(pin, 1);
// disable all output to save power
turnOff(0);
turnOff(2);
turnOff(4);
turnOff(5);
turnOff(12);
turnOff(13);
turnOff(14);
turnOff(15);
dht.begin();
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
int value = 0;
delay(5000);
++value;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
String temp = String(dht.readTemperature());
String humidity = String(dht.readHumidity());
String url = "/update?key=";
url += thingspeak_key;
url += "&field1=";
url += temp;
url += "&field2=";
url += humidity;
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
while(client.available()){
Serial.print(line);
Serial.println("closing connection. going to sleep...");
delay(1000);
// go to deepsleep for few minutes
system_deep_sleep_set_option(0);
system_deep_sleep(0.5 * 60 * 1000000);
