By primateio
#40997 I am using the ArduinoWebSocket library here. https://github.com/Links2004/arduinoWebSockets. I have my esp8266 acting as a server and using the demo code. I have it serving a webpage and I want to be able to send chunks of data with variables through the web-socket and interprete them. I basically need 2 int sent through, preferably in one datastream. The problem is, the library seems to get the payload as an uint8_t * array (unsigned char array). And the callback that it uses is like this.
Code: Select allvoid webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t lenght) {
  delay(1);
  switch (type) {
      case WStype_TEXT:
            DBG_OUTPUT_PORT.printf("[%u] get Text: %s\n", num, payload);
            break;
Does anyone have any idea how I can send a string such as "x654y33" and be able to turn it into,
int x = 654;
int y = 33;
If i can get it into a String I can manipulate it pretty easy in arduino, but so far, everything I try either does not compile, or it does compile but crashes the esp8266 as soon as the websocket sends data.
Thanks in advance.
By martinayotte
#40999 There is many ways to fix such issue.
Since the webSocketEvent() is receiving "uint8_t * payload" which look like a simple string, the easiest one would be to use ArduinoJson and send a JSON structure such as :
Code: Select all{ "x": 654, "y": 33}
If Link2004 WebSocket library is supporting "binary" payload (which I don't know yet, I have to look at it), then a simple C structure could be use :
Code: Select alltypedef struct {
  int x;
  int y;
} coordinate;
But in such case, we need to pay attention if both sender/receiver are compatible, because having "little endian" conflict with "big endian" can become an issue.
By primateio
#41000 Thanks for your reply . I just figured it out and was coming back to post what I got working for future users. Here is what I did to get it working. This is probably not best practice, but worked for me. Instead of sending something like "x334y543" I just send "334 543". Since I am only going to be sending 2 vars, this works. I break out the data into int32_t using the following code.
Code: Select allint32_t x;
int32_t y;
char *tmp;
x = (int32_t) strtol((const char *)payload,&tmp,0);
y = (int32_t)strtol(tmp,&tmp,0);
It is working great so far. I might look into it a little more to be able to send a better payload, but for what I need for this project, it works. I just have to make sure I always send the payload in the right order.
