Error in read PWM from an RC Receiver
PostPosted: Mon Feb 15, 2016 7:25 pm
by jairbj
Hi friends, I'm trying to read a pwm signal from my RC Receiver but anything is wrong with the results.
I tryed to run this code:
Code: Select allbyte PWM_PIN = D2;
int pwm_value;
  pinMode(PWM_PIN, INPUT);
  pwm_value = pulseIn(PWM_PIN, HIGH);
  Serial.println(pwm_value);
But it gives me so many random values:
1
10
467
2
1
2
1
2
1
1
1
1
1
2
1
2
1
2
1
4834
44
4873
41
106
76
42
623
1
1
2
393
If I plug an servo to this receiver it works great.
According to this picture this should be the values I need to get.
Could you help me?
Re: Error in read PWM from an RC Receiver
PostPosted: Sun Jun 12, 2016 4:54 am
by scanboostar
Hello,
I'm using the following code:
Code: Select all#define PWM_Source 2 // Pin GPIO2 of ESP01
#define Output_PIN 0 // Pin GPIO0 of ESP01
  pinMode(PWM_Source, INPUT_PULLUP);
  pinMode(Output_PIN, OUTPUT);
int pwmin;
int pwmhist = 1500;
 pwmin = pulseIn(PWM_Source, HIGH, 20000);
  delay(30);
 if (pwmin == 0){     // filter out the "0" values
    pwmin = pwmhist;
 } else {
    pwmhist = pwmin;
 Serial.println((String)pwmin); // for debugging
 if (pwmin < 1475 || pwmin > 1515 ){
    digitalWrite(Output_PIN, HIGH);
 } else {
    digitalWrite(Output_PIN, LOW);
