Serving images with webserver class
Posted: Thu Feb 25, 2016 4:30 pm
I've generated a html form from phpform.org, something with just a multiple choice box and a text input field which I want to serve form a esp8266.
To serve the generated form I've converted the text components with txt2c (https://sourceforge.net/projects/txt2c/) and converted the binary files (png & gif) with bin2hex.
I then included all these as header files, and added commands like server.on("blank.gif", handleBlankGif);
Where that function looks like
void handleBlankGif()
Serial.println("Handle Gif");
server->sendImage( 200, "image/gif", blank_gif, blank_gif_size);
Then had to add the follow two functions (and appropriate header) to ESP8266WebServer.cpp as the send would terminate early since the binary data has '\0' in it.
void ESP8266WebServer::sendImage(int code, const char* content_type, const char *image, int image_size) {
String header;
_prepareHeader(header, code, content_type, image_size);
sendContent(header);
sendContent(image, image_size);
void ESP8266WebServer::sendContent(const char *image, int image_size) {
const size_t unit_size = HTTP_DOWNLOAD_UNIT_SIZE;
size_t size_to_send = image_size;
const char* send_start = image;
while (size_to_send) {
size_t will_send = (size_to_send < unit_size) ? size_to_send : unit_size;
size_t sent = _currentClient.write(send_start, will_send);
if (sent == 0) {
break;
size_to_send -= sent;
send_start += sent;
This works but there must be a better way (and if the libraries get updated there goes my hack). Is there a way to upload the support files (.html, .css, .js, .png, etc) to the file system and serve directly form there?
Thanks,
Timothy
String header;
if (sent == 0) {
break;
send_start += sent;
Thanks,
Timothy
