By MethowBird
#42269 Hi everyone,
I'm new to this forum and programming in general so forgive me in advance if my questions seem a bit basic.
Before I begin detailing my problem, let me explain what I'm doing. My goal is to create a PIR motion sensor located in a hallway and linked to and EasyIoT server. This is both for utility and to learn along the way. The idea is to then use Pushbullet, (and a tutorial that I found here on the forums) to send my phone and computer a push notification when there is motion. (Doesn't seem impossible to me...)
Because of the location of the sensor, (it must be small/somewhat hidden) and cannot use a standard wall plug as power source. No problem, I've figured a solution to that using a Lipo and a PowerBoost module.
The PIR sensor is 5V input with 3.3V logic. My reasoning behind using the feather was that it would solve many things at once: FDTI, charger for my lipo, ESP8266 module, 3.3v logic, and 5V out (for the PIR). Again I want to keep it as small as possible.
Now here comes my issue/error. I am programming the Feather using Arduino IDE, having set my board to "Generic ESP8266 Module" as instructed in the manual. I am not too familiar with coding, so I started looking for examples. I found this on iot-playground which I think should be perfect (correct me if I'm wrong):
http://iot-playground.com/blog/2-uncategorised/42-esp8266-wifi-pir-motion-sensor-arduino-ide
Below is my code and the error following when I tried to upload. In my searching the web I found the biggest cause to be missing libraries, but those are installed in the same location as the default libraries.
Again, I am very new to this, any help, explanations, tutorials, etc, would be greatly appreciated.
Thanks,
Luigi
Code: Select all
  Created by Igor Jarc
 See http://iot-playground.com for details
 Please use community forum on website do not contact author directly
 External libraries:
 - https://github.com/adamvr/arduino-base64
 This program is free software; you can redistribute it and/or
 modify it under the terms of the GNU General Public License
 version 2 as published by the Free Software Foundation.
#include <Base64.h>
//AP definitions
#define AP_SSID "AeroWifi"
#define AP_PASSWORD "xxxxx"
// EasyIoT server definitions
#define EIOT_USERNAME    "xxxxxxx"
#define EIOT_PASSWORD    "xxxxxxxx"
#define EIOT_IP_ADDRESS  "xxx.xxx.x.xxx"
#define EIOT_PORT        "80"
#define EIOT_NODE        "N20S0"
#define INPUT_PIN         2
#define USER_PWD_LEN      40
char unameenc[USER_PWD_LEN];
bool oldInputState;
  pinMode(INPUT_PIN, INPUT);
  wifiConnect();
  char uname[USER_PWD_LEN];
  String str = String(EIOT_USERNAME)+":"+String(EIOT_PASSWORD);
  str.toCharArray(uname, USER_PWD_LEN);
  memset(unameenc,0,sizeof(unameenc));
  base64_encode(unameenc, uname, strlen(uname));
  oldInputState = !digitalRead(INPUT_PIN);
  int inputState = digitalRead(INPUT_PIN);;
  if (inputState != oldInputState)
    sendInputState(inputState);
    oldInputState = inputState;
void wifiConnect()
    Serial.print("Connecting to AP");
    WiFi.begin(AP_SSID, AP_PASSWORD);
    delay(1000);
    Serial.print(".");
  Serial.println("");
void sendInputState(bool inputState)
   WiFiClient client;
   while(!client.connect(EIOT_IP_ADDRESS, EIOT_PORT)) {
    wifiConnect();
  String url = "";
  String command = "";
  if (inputState)
    command = "ControlOn";
    command = "ControlOff";
  url = "/Api/EasyIoT/Control/Module/Virtual/"+ String(EIOT_NODE) + "/"+command; // generate EasIoT server node URL
  Serial.print("POST data to URL: ");
  Serial.println(url);
  client.print(String("POST ") + url + " HTTP/1.1\r\n" +
               "Host: " + String(EIOT_IP_ADDRESS) + "\r\n" +
               "Connection: close\r\n" +
               "Authorization: Basic " + unameenc + " \r\n" +
               "Content-Length: 0\r\n" +
               "\r\n");
  delay(100);
    while(client.available()){
    Serial.print(line);
  Serial.println("Connection closed");
AND THE ERROR:
Code: Select allArduino: 1.6.7 (Windows 10), Board: "Generic ESP8266 Module, Serial, 80 MHz, 40MHz, QIO, 115200, 512K (64K SPIFFS), nodemcu, Disabled, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Luigi\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Luigi\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Luigi\Documents\Arduino\libraries" -fqbn=esp8266:esp8266:generic:UploadTool=esptool,CpuFrequency=80,FlashFreq=40,FlashMode=qio,UploadSpeed=115200,FlashSize=512K64,ResetMethod=nodemcu,Debug=Disabled,DebugLevel=None____ -ide-version=10607 -build-path "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Luigi\Documents\Arduino\IoT\Motion_Sensor\sketch_mar01a\sketch_mar01a.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Luigi\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Luigi\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Luigi\Documents\Arduino\libraries" -fqbn=esp8266:esp8266:generic:UploadTool=esptool,CpuFrequency=80,FlashFreq=40,FlashMode=qio,UploadSpeed=115200,FlashSize=512K64,ResetMethod=nodemcu,Debug=Disabled,DebugLevel=None____ -ide-version=10607 -build-path "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Luigi\Documents\Arduino\IoT\Motion_Sensor\sketch_mar01a\sketch_mar01a.ino"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp\sketch\sketch_mar01a.ino.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp\sketch\sketch_mar01a.ino.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\WiFiClient.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\WiFiClientSecure.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\WiFiServer.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src\WiFiUdp.cpp" -o "nul"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266       "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp\sketch\sketch_mar01a.ino.cpp" -o "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0/tools/sdk/include" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L   -DARDUINO=10607 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266  -DESP8266 "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\cores\esp8266" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\variants\generic" "-IC:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src" "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp\sketch\sketch_mar01a.ino.cpp" -o "C:\Users\Luigi\AppData\Local\Temp\buildc1caefdb854a46d4ea9ec9124efe2f41.tmp\sketch\sketch_mar01a.ino.cpp.o"
C:\Users\Luigi\Documents\Arduino\IoT\Motion_Sensor\sketch_mar01a\sketch_mar01a.ino: In function 'void setup()':
sketch_mar01a:39: error: 'wifiConnect' was not declared in this scope
   wifiConnect();
sketch_mar01a:45: error: 'base64_encode' was not declared in this scope
C:\Users\Luigi\Documents\Arduino\IoT\Motion_Sensor\sketch_mar01a\sketch_mar01a.ino: In function 'void loop()':
sketch_mar01a:55: error: 'sendInputState' was not declared in this scope
C:\Users\Luigi\Documents\Arduino\IoT\Motion_Sensor\sketch_mar01a\sketch_mar01a.ino: In function 'void sendInputState(bool)':
sketch_mar01a:77: error: invalid conversion from 'const char*' to 'uint16_t {aka short unsigned int}' [-fpermissive]
In file included from C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                 from C:\Users\Luigi\Documents\Arduino\IoT\Motion_Sensor\sketch_mar01a\sketch_mar01a.ino:13:
C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi\src/WiFiClient.h:48:15: error:   initializing argument 2 of 'virtual int WiFiClient::connect(const char*, uint16_t)' [-fpermissive]
   virtual int connect(const char *host, uint16_t port);
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Luigi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\ESP8266WiFi
exit status 1
By Valhalla
#48129 Hi MethowBird,
If you take away all of the extras (libraries and sensors), can you upload a simple sketch successfully? If not, try following this simple tutorial to get up and running:
http://imaginen4tion.blogspot.com/2015/ ... fruit.html
Using the Huzzah Feather, I have always chosen "Adafruit HUZZAH ESP8266" as the board to in the Arduino IDE. Also, version 1.6.6 of the Arduino IDE doesn't play nicely, if you are using that version get a different one.
