Page 1 of 2
Use SW to determine which Arduino version I'm running.....
PostPosted: Sat Mar 12, 2016 7:34 pm
by xtal
Is there any way to use ESP Arduino Software to detect what Arduino version the sketch
was compiled with?
Re: Use SW to determine which Arduino version I'm running...
PostPosted: Sun Mar 13, 2016 4:46 am
by PaulRB
Sounds like an "XY problem" to me!
Paul
PostPosted: Sun Mar 13, 2016 5:31 am
by krzychb
Hi xtal,
To detect what Arduino version the sketch was compiled with you can check ARDUINO constant.
Sample sketch:
Code: Select allvoid setup()
  Serial.print("The 'ARDUINO' constant contains: ");
  Serial.println(ARDUINO);
  if(ARDUINO == 10608)
    Serial.println("You are running Arduino IDE 1.6.8");
void loop() {}
Output on serial monitor:
Code: Select allThe 'ARDUINO' constant contains: 10608
Krzysztof
PostPosted: Sun Mar 13, 2016 8:23 am
by xtal
Thanks Krzysztof I'll give it a try...
