malachi wrote:Is anyone able to achieve cooperative multitasking?
I suspect you have read this thread, it discusses with examples the eSP8266 in an Arduino environment with simplistic Preemptive/Cooperative examples. I'm not really pleased with the example implementations, but it is a start.
I suspect that one could roll-their-own methodology based on a state-machine and the ms timer. The major problem with getting too fancy is that one must absolutely yield often so that the currently implemented "multitask" Arduino-on-ESP8266 can service the RF section of the binary; this means using delay(0) or yield() or ensuring that the loop() function completes no longer than approximately 20mS --50mS max.
WiFi and TCP/IP libraries get a chance to handle any pending events each time the loop() function completes, OR when delay is called. If you have a loop somewhere in your sketch that takes a lot of time (>50ms) without calling delay, you might consider adding a call to delay function to keep the WiFi stack running smoothly.
There is also a yield() function which is equivalent to delay(0). The delayMicroseconds function, on the other hand, does not yield to other tasks, so using it for delays more than 20 milliseconds is not recommended.
https://github.com/esp8266/Arduino/blob/master/doc/reference.mdSo, if you set up your tasks something like:
Code: Select allvoid loop()
task1();
task2();
task3();
... and you profile all three tasks (that is, the total time to process loop() and it takes less than 20mS, there is nothing to worry about. The top of the loop will automatically call yield().
... or, if you profile all three tasks and the time is > 20mS, you can put a yield() between two of the tasks; or simply put a yield() after task1, after task2 remembering that there is an implied yield() after task3 (end of loop == top of loop for timing.)
So, thinking like the above, you have the following:
task1();
yield();
task2();
yield();
task3();
// yield() // implied
To be super safe, profile each taskx and make certain none are over 50mS maximum!
Ray
