OTA - ESPhttpUpdate crash
Posted: Mon Mar 21, 2016 6:22 am
Hi, I get the following crash when I try to update the node in my sketch, any idea of the cause? If a make a standalone sketch just to test the upgrade it (sort of) works, it doesn't crash and it works not immediatly after I program it to the node, but works after programming and reseting the node. I'm using the NodeMCU 0.9 configuration, with a custom board with an ESP12 module. Could it be a RAM issue, since it works with a simple sketch and not with this sketch?
Thanks in advance!
Fernando
Code:
Result:
Thanks in advance!
Fernando
Code:
Serial.println("\nChecking if there is an updated firmware");
t_httpUpdate_return ret = ESPhttpUpdate.update(upgradeFile);
Serial.print("Update: ");
Serial.println(ret);
switch(ret) {
case HTTP_UPDATE_FAILED:
Serial.printf("HTTP_UPDATE_FAILD Error (%d): %s", ESPhttpUpdate.getLastError(), ESPhttpUpdate.getLastErrorString().c_str());
break;
case HTTP_UPDATE_NO_UPDATES:
Serial.println("HTTP_UPDATE_NO_UPDATES");
break;
case HTTP_UPDATE_OK:
Serial.println("HTTP_UPDATE_OK");
break;
Result:
Exception (29):
epc1=0x40213f38 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff5420 end: 3fff5990 offset: 01a0
>>>stack>>>
3fff55c0: 3fff2b30 00057000 00000000 40213f31
3fff55d0: 3ffed0a4 00020000 3ffeca9c 3fff5aa4
3fff55e0: 00000000 00000000 3fff6138 40212d9c
3fff55f0: 00056df0 00000000 3fff6138 40212a0d
3fff5600: 00001000 00056df0 3fff5640 40214478
3fff5610: 3ffeca9c 00000000 3fff5680 00000001
3fff5620: 3fff5aa4 00056df0 3fff4874 402104eb
3fff5630: 3ffec0b0 00000000 000003e8 40214550
3fff5640: 3fff64f0 0000000f 00000000 4020fcd0
3fff5650: 3fff6138 3fff5aa4 3fff5680 3fff4970
3fff5660: 40210df0 001640c8 3fff6138 3fff59b8
3fff5670: 3fff6138 3fff4874 3fff56e0 402107ff
3fff5680: 3fff64d8 0000000f 00000000 400001e9
3fff5690: 00000000 00000000 3ffebb3c 40214348
3fff56a0: 00056df0 00000000 00000000 00000001
3fff56b0: 00400000 00000000 00000000 00000000
3fff56c0: 00000000 00000000 3fff56e0 3ffeca9c
3fff56d0: 00000001 3fff4874 3ffeca9c 402108e5
3fff56e0: 3fff6138 00000000 3fff5c00 0000000f
3fff56f0: 0000000f 00000050 3f011f40 3fff6198
3fff5700: 0000002f 00000020 3fff5900 3fff6018
3fff5710: 0000000f 00000000 3fff61d0 000000ef
3fff5720: 000000e6 3fff60f8 0000001f 00000013
3fff5730: 3fff60e0 0000000f 00000000 3fff6034
3fff5740: 00000001 000000c8 00056df0 40211800
3fff5750: 00000000 3fff365c 3fff59e0 40211809
3fff5760: 3fff5790 00000000 3fff59e0 40213a4c
3fff5770: 3fff59e0 3fff365c 3fff59e0 3ffe9118
3fff5780: 0000003e 3fff365c 3fff59e0 40207cda
3fff5790: 70747468 632f2f3a 72746e6f 65726c6f
3fff57a0: 632e6564 702f6d6f 6163646f 502f7473
3fff57b0: 6163646f 70537473 656b6165 632e3172
3fff57c0: 622e7070 fe006e69 feefeffe feefeffe
3fff57d0: feefeffe feefeffe feefeffe feefeffe
3fff57e0: feefeffe feefeffe feefeffe feefeffe
3fff57f0: feefeffe feefeffe feefeffe feefeffe
3fff5800: feefeffe feefeffe feefeffe feefeffe
3fff5810: feefeffe feefeffe feefeffe feefeffe
3fff5820: feefeffe feefeffe feefeffe feefeffe
3fff5830: feefeffe feefeffe feefeffe feefeffe
3fff5840: feefeffe feefeffe feefeffe feefeffe
3fff5850: feefeffe feefeffe feefeffe feefeffe
3fff5860: feefeffe feefeffe feefeffe feefeffe
3fff5870: feefeffe feefeffe feefeffe feefeffe
3fff5880: feefeffe feefeffe feefeffe feefeffe
3fff5890: 00000000 00000000 3ffeb644 00000000
3fff58a0: 3fff67b8 0000000f 00000000 3fff67d0
3fff58b0: 0000000f 00000000 00000000 00000000
3fff58c0: 00000000 3ffebe78 00000000 3ffebe78
3fff58d0: 00000000 3ffebe78 00000000 3ffebe78
3fff58e0: 00000000 3ffebe78 00000000 3ffebe78
3fff58f0: 00000000 00000000 ffffffff feef0000
3fff5900: 00000000 fe01ef35 00000000 00000000
3fff5910: feefeffe feefeffe feefeffe feefeffe
3fff5920: feefeffe feefeffe feefeffe feefeffe
3fff5930: feefeffe feefeffe feefeffe feefeffe
3fff5940: feefeffe feefeffe feefeffe feefeffe
3fff5950: feefeffe feefeffe feefeffe feefeffe
3fff5960: feefeffe feefeffe feefeffe 3fff4964
3fff5970: 3fffdad0 00000000 3fff495c 40210c54
3fff5980: feefeffe feefeffe 3fff4970 40100114
<<<stack<<<
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
