It hangs at client.connect for some time.. and then connection fails.
the same happens in "google.com" or "www.google.com"
other hosts work and reply normally
Is it my network?
* HTTP over TLS (HTTPS) example sketch
* This example demonstrates how to use
* WiFiClientSecure class to access HTTPS API.
* We fetch and display the status of
* esp8266/Arduino project continuous integration
* build.
* Created by Ivan Grokhotkov, 2015.
* This example is in public domain.
// Replace with your network credentials
const char* ssid = ".....";
const char* password = ".........";
const char* host = "calendar.google.com";
const int httpsPort = 443;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
//const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
const char* fingerprint = "99 70 D6 7C B8 42 71 18 DC A6 88 DB DC C8 69 66 96 9D 51 88"; //google
Serial.begin(57600);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Use WiFiClientSecure class to create TLS connection
WiFiClientSecure client;
Serial.println(host);
if (!client.connect(host, httpsPort)) {
return;
if (client.verify(fingerprint, host)) {
Serial.println("certificate matches");
} else {
Serial.println("certificate doesn't match");
String url = "/";
Serial.print("requesting URL: ");
Serial.println(url);
"Host: " + host + "\r\n" +
"User-Agent: ESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
while (client.connected()) {
String line = client.readStringUntil('\n');
if (line == "\r") {
Serial.println("headers received");
break;
Serial.println("reply was:");
Serial.println("==========");
Serial.println(line);
output is
connecting to ssid
WiFi connected
IP address:
192.168.1.11
connecting to calendar.google.com
connection failed
https://nobugsjustfeatures.wordpress.com/
