Any ideas on what might be happening? I've tried several different power supplies, etc.
Thanks!
The sketch:
#include <DallasTemperature.h>
//onewire appears to be included by ESP8266WiFi lib
// Read internal vcc rather than voltage on ADC pin (A0 must be floating)
ADC_MODE(ADC_VCC);
// Assign to pin D3 of your NodeMCU to the DS18B20
#define ONE_WIRE_BUS D3
// Create a onewire instanace
OneWire oneWire(ONE_WIRE_BUS);
// Declare a DS18B20 Instance and assing the OneWire reference to it.
DallasTemperature sensors(&oneWire);
DeviceAddress tempDeviceAddress;
const int sensorPower = D5;
const int resolution = 10;
const int attempts = 2;
const int httpPort = 80;
// 15 minutes
const unsigned long sleepMicros = 945000000;
const char* ssid = "Wireless";
const char* password = "Zx898yxchky9";
const char* host = "www.xxxxxxx.com";
const char* sensorID = "esp00001";
float tempReading;
int batVcc;
int connectAttempts;
void goToSleep() {
//Serial.println("Going to sleep");
digitalWrite(sensorPower, LOW);
ESP.deepSleep(sleepMicros, WAKE_RF_DEFAULT);
void myDelay(int ms) {
int i;
for(i=1;i!=ms;i++) {
delay(1);
if(i%100 == 0) {
ESP.wdtFeed();
yield();
pinMode(sensorPower, OUTPUT);
digitalWrite(sensorPower, HIGH);
connectAttempts = 0;
//Start the DallasTemperature Library
sensors.begin();
sensors.getAddress(tempDeviceAddress, 0);
sensors.setResolution(tempDeviceAddress, resolution);
sensors.setWaitForConversion(false);
sensors.requestTemperatures(); // Tell the DS18B20 to get make a measurement
myDelay(100);
WiFi.begin(ssid, password);
myDelay(200);
myDelay(200);
tempReading = sensors.getTempCByIndex(0);
myDelay(100);
batVcc = ESP.getVcc();
if (connectAttempts >= attempts) {
goToSleep();
myDelay(1000);
WiFiClient client;
myDelay(100);
connectAttempts++;
return;
// We now create a URI for the request
String url = "/sensornet/html/";
url += "espnet.php";
url += "?sid=";
url += sensorID;
url += "&t=";
url += tempReading;
url += "&b=";
url += batVcc;
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
myDelay(1500);
while(client.available()){
goToSleep();
