Page 1 of 3
80Mhz vs. 160Mhz (not so stable at 160??)
Posted:
Wed Apr 13, 2016 11:29 am
by RichardS
I have great success with my Arduino sketches at 80Mhz, but when I set the options in the IDE to use 160Mhz, typically it will cause the code that worked 100% at 80Mhz not to work anymore.....
Anyone else have similar findings?
RichardS
Re: 80Mhz vs. 160Mhz (not so stable at 160??)
Posted:
Wed Apr 13, 2016 12:23 pm
by xtal
I just tried a sketch {has no wifi] on ESP-201 at 160 mhz looks like it working fine,,, Of course it is a prog under test ....
Posted:
Wed Apr 13, 2016 12:31 pm
by RichardS
With no wifi will probably work, mine prints to the serial port, but when wifi starts, it stops.
RIchardS
Posted:
Wed Apr 13, 2016 4:32 pm
by xtal
tried another sketch using wifi,,, page updates every 8 seconds , I can output serial no problems ..
my serial inp uses BT serial and that link is down now ,,,
all appears to be normal,,,,,
May stick with 160 , page updating is quicker.......
