Connecting ESP8266 Dev Kit to SparkFun ToF VL6180 Sensor
Posted: Fri Apr 15, 2016 5:07 am
Hey guys,
I am currently trying to connect the SparkFun ToF Range Finder Sensor - VL6180 to NodeMCU 1.0(ESP-12E) but am getting this error via Arduino IDE 1.6.8's serial Monitor.
ets Jan 8 2013.rst cause:2. boot mode:(3,6)
load ox4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
Code:
#include <Wire.h>
#include <SparkFun_VL6180X.h>
/*const float GAIN_1 = 1.01; // Actual ALS Gain of 1.01
const float GAIN_1_25 = 1.28; // Actual ALS Gain of 1.28
const float GAIN_1_67 = 1.72; // Actual ALS Gain of 1.72
const float GAIN_2_5 = 2.6; // Actual ALS Gain of 2.60
const float GAIN_5 = 5.21; // Actual ALS Gain of 5.21
const float GAIN_10 = 10.32; // Actual ALS Gain of 10.32
const float GAIN_20 = 20; // Actual ALS Gain of 20
const float GAIN_40 = 40; // Actual ALS Gain of 40
#define VL6180X_ADDRESS 0x29
VL6180xIdentification identification;
VL6180x sensor(VL6180X_ADDRESS);
Serial.begin(115200); //Start Serial at 115200bps
Wire.begin(4, 5); //Start I2C library
delay(100); // delay .1s
sensor.getIdentification(&identification); // Retrieve manufacture info from device memory
printIdentification(&identification); // Helper function to print all the Module information
if(sensor.VL6180xInit() != 0){
Serial.println("FAILED TO INITALIZE"); //Initialize device and check for errors
sensor.VL6180xDefautSettings(); //Load default settings to get started.
delay(1000); // delay 1s
//Get Ambient Light level and report in LUX
Serial.print("Ambient Light Level (Lux) = ");
//Input GAIN for light levels,
// GAIN_20 // Actual ALS Gain of 20
// GAIN_10 // Actual ALS Gain of 10.32
// GAIN_5 // Actual ALS Gain of 5.21
// GAIN_2_5 // Actual ALS Gain of 2.60
// GAIN_1_67 // Actual ALS Gain of 1.72
// GAIN_1_25 // Actual ALS Gain of 1.28
// GAIN_1 // Actual ALS Gain of 1.01
// GAIN_40 // Actual ALS Gain of 40
Serial.println( sensor.getAmbientLight(GAIN_1) );
//Get Distance and report in mm
Serial.print("Distance measured (mm) = ");
Serial.println( sensor.getDistance() );
void printIdentification(struct VL6180xIdentification *temp){
Serial.print("Model ID = ");
Serial.println(temp->idModel);
Serial.print("Model Rev = ");
Serial.print(temp->idModelRevMajor);
Serial.println(temp->idModelRevMinor);
Serial.print("Module Rev = ");
Serial.print(temp->idModuleRevMajor);
Serial.println(temp->idModuleRevMinor);
Serial.print("Manufacture Date = ");
Serial.print((temp->idDate >> 3) & 0x001F);
Serial.print("/");
Serial.print((temp->idDate >> 8) & 0x000F);
Serial.print("/1");
Serial.print((temp->idDate >> 12) & 0x000F);
Serial.print(" Phase: ");
Serial.println(temp->idDate & 0x0007);
Serial.print("Manufacture Time (s)= ");
Serial.println(temp->idTime * 2);
Any help is highly appreciated. Thanks
Cheers,
DarkWarrior
tail 0
chksum 0x42
csum 0x42
~ld
Code:
#include <Wire.h>
Serial.print("/");
Serial.print("/1");
Cheers,
DarkWarrior
