server.handleClient();but I'm not sure that is helpful. Is there any way to get the remote IP with ESP8266WebServer?
Explore... Chat... Share...
server.handleClient();martinayotte wrote:I'm not sure I understand your question...
If you don't do regular calls to server.handleClient() in the loop(), your ESP8266WebServer will simply not work !
webserver.client().remoteIP();It takes about 20-25 seconds for home assistant c[…]
