Can't find what I'm doing wrong.
I have:
1) ESP12F
2) FTDI232 programmer (jumper is on 3.3V)
3) 4x1.5 V batteries
4) LD1117AV33 voltage regulator
5) some resistors, capacitors and wires
Originally I was using this circuit - http://i1.wp.com/esp8266.ru/wp-content/ ... jpg?w=1170
My current circuit is - http://screencast.com/t/68qg9Ps8
* gray wire is used to enable programming mode (should be removed in normal mode)
* near regulator I have 0.1mf capacitor
* other capacitor is 100mf (also tried with 0.1mf)
* led is connected throw R100 to GPIO4
From regulator I have constant 3.25V (tested with multimeter)
Trying to upload from Arduino IDE simple scatch:
void setup(void) {
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
digitalWrite(4, LOW);
Arduino IDE settings - http://screencast.com/t/G8KDJMFh
To start uploading:
1. GPIO0 is low (gray wire)
2. I press "reset" button (blue led flashes 1 time)
3. from Arduino IDE press "Upload" button
4. Uploading is starting. Blue led is blinking while uploading.
5. And it's freezing when it should finish (blue led stops blinking)
This is how it looks (video) - http://screencast.com/t/nk5Iqs4cjUR
And if I remove gray wire, reset esp, each ~10 sec I get message in serial monitor:
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x0f
csum 0x0f
~ld
What I'm doing wrong or what should I else do?
