Chat here about code rewrites, mods, etc... with respect to the github project https://github.com/esp8266/Arduino
By daOEKL
#55443 Hi guys,
I am very new but after days of googling I decided to ask for help in a Forum.
I do hope I do not upset you with my question..
Here is my problem:
I followed an example I found in the web to set up a simple webserver:
First I built a simple webpage with a free editor.
Second I used a tool to convert this html file to a "string".
Third I opend an Arduino-Example: "mDNS_Web_Server" and changed the "String s" by pasting my own converted html file.
Now the webserver is running.
So far everything is working fine but now I want to use a stylsheet: "myOwnStyle.css" by storing it on my esp via SPIFFS.
I succesfully used a recommended tool to store the *.css-file on the esp.
I also included "FS.h" and followed some advice of this page: http://esp8266.github.io/Arduino/versio ... ystem.html
but if i follow the serial Monitor and go to the "printed" ip, the stylsheet is not found.
I would like to know, what I need to do to succesfully use a stylsheet stored on spiffs.
Here is my actual code:
The modified example
Code: Select all/*
  ESP8266 mDNS responder sample
  This is an example of an HTTP server that is accessible
  via http://esp8266.local URL thanks to mDNS responder.
  Instructions:
  - Update WiFi SSID and password as necessary.
  - Flash the sketch to the ESP8266 board
  - Install host software:
    - For Linux, install Avahi (http://avahi.org/).
    - For Windows, install Bonjour (http://www.apple.com/support/bonjour/).
    - For Mac OSX and iOS support is built in through Bonjour already.
  - Point your browser to http://esp8266.local, you should see a response.
#include <ESP8266mDNS.h>
#include <WiFiClient.h>
#include "yeah.h"
#include "FS.h"
const char* ssid = "mySSid";
const char* password = "abc..**********";
// TCP server at port 80 will respond to HTTP requests
WiFiServer server(80);
void setup(void)
  SPIFFS.begin();
  // Connect to WiFi network
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.println(ssid);
  Serial.print("IP address: ");
  // Set up mDNS responder:
  // - first argument is the domain name, in this example
  //   the fully-qualified domain name is "esp8266.local"
  // - second argument is the IP address to advertise
  //   we send our IP address on the WiFi network
  if (!MDNS.begin("esp8266")) {
    Serial.println("Error setting up MDNS responder!");
    while(1) {
      delay(1000);
  Serial.println("mDNS responder started");
  // Start TCP (HTTP) server
  server.begin();
  Serial.println("TCP server started");
  // Add service to MDNS-SD
  MDNS.addService("http", "tcp", 80);
void loop(void)
  if (!client) {
    return;
  Serial.println("");
  Serial.println("New client");
  // Wait for data from client to become available
  while(client.connected() && !client.available()){
    delay(1);
  // Read the first line of HTTP request
  // First line of HTTP request looks like "GET /path HTTP/1.1"
  // Retrieve the "/path" part by finding the spaces
  int addr_start = req.indexOf(' ');
  int addr_end = req.indexOf(' ', addr_start + 1);
  if (addr_start == -1 || addr_end == -1) {
    Serial.print("Invalid request: ");
    Serial.println(req);
    return;
  req = req.substring(addr_start + 1, addr_end);
  Serial.print("Request: ");
  client.flush();
  String s;
  if (req == "/")
    IPAddress ip = WiFi.localIP();
    s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
    s += file1;
    s += "</html>\r\n\r\n";
    Serial.println("Sending 200");
  else if (req =="/KaffeStyle.css")
    File KaffeStyle = SPIFFS.open("/KaffeStyle.css", "r");
    if (!KaffeStyle) {
      Serial.println("Css Datei nichtgefunden");
    else if(KaffeStyle) Serial.println("file Opened");
    s = "HTTP/1.1 404 Not Found\r\n\r\n";
    Serial.println("Sending 404");
  client.print(s);
  Serial.println("Done with client");
and my "converted" webpage-file
Code: Select all#ifndef header_h
#define header_h
String file1=
"!DOCTYPE HTML PUBLIC -W3CDTD HTML 4.01 TransitionalEN httpwww.w3.orgTRhtml4loose.dtd\r\n"
"html\r\n"
"         head\r\n"
"                 titleSteuerungtitle\r\n"
"                 link rel=stylesheet type=textcss href=MyStyle.css \r\n"
"         head\r\n"
"         body\r\n"
"         div id=mainframe\r\n"
"\r\n"
"                         div id=tastenAuswahl\r\n"
"                              button type=button class=button1x klbuttonbutton type=button class=button2x klbuttonbr\r\n"
"                              button type=button class=button1x mibuttonbutton type=button class=button2x mibuttonbr\r\n"
"                              button type=button class=button1x grbuttonbutton type=button class=button2x grbuttonbr\r\n"
"                         div\r\n"
"\r\n"
"\r\n"
"\r\n"
"\r\n"
"         div\r\n"
"         body\r\n"
"html\r\n";
#endif
By mrburnette
#55509 I was looking over an advanced webpage example I have downloaded to see how the css was utilized:
In webpage.h
Code: Select allvoid setupPageHandlers() {
  server.serveStatic("/", SPIFFS, "/index.html");
  server.serveStatic("/about.html", SPIFFS, "/about.html");
  server.serveStatic("/index.html", SPIFFS, "/index.html");
  server.serveStatic("/settings.html", SPIFFS, "/settings.html");
  server.serveStatic("/css/dropdown.css", SPIFFS, "/css/dropdown.css");
  server.serveStatic("/css/fonts.css", SPIFFS, "/css/fonts.css");
  server.serveStatic("/css/normalize.min.css", SPIFFS, "/css/normalize.min.css");
  server.serveStatic("/css/skeleton.min.css", SPIFFS, "/css/skeleton.min.css");
  server.serveStatic("/images/favicon.png", SPIFFS, "/images/favicon.png");
  server.serveStatic("/js/jquery-2.1.4.min.js", SPIFFS, "/js/jquery-2.1.4.min.js");
So, it appears to be a relative path to SPIFFS. I zipped up the entire example for your review since I failed to drop a URL into the folder to identify the sources.
Ray
