But you need to change the code for the timeoutWait function
while((long)(micros() - resumeTime) < 0L); // (syntax is rollover-proof)to:
delay(10); Explore... Chat... Share...
while((long)(micros() - resumeTime) < 0L); // (syntax is rollover-proof)delay(10); It takes about 20-25 seconds for home assistant c[…]
