Was given this:
extern void esp_wifi_set_promiscuous_data_len(uint32_t len);Tested and works perfectly with RTOS_SDK-3.2
Any chance this can be a part of the Arduino ESP8266 core?
Explore... Chat... Share...
extern void esp_wifi_set_promiscuous_data_len(uint32_t len);It takes about 20-25 seconds for home assistant c[…]
