nodemcuv2.build.flash_mode=qioModerator: igrr
Dual IO uses 2 lines for data
Standard uses a single line for data
You need to use the mode that the flash part supports. The datasheet for the part should describe the modes that it supports. The HW design also has to have the lines connected.
