I'm trying out an SSD1306 display with Adafruit's 128*64 I2C example.
First I tried the original Adafruit's library (with necessary adjustments, e.g. baud rate, I2C address, etc.). The program worked for the few first commands (display buffer, display a pixel) stopped at the testdrawline() routine, having drawn some line. On the serial monitor, it says
ctx: cont
sp: 3ffea4d0 end: 3ffea760 offset: 01b0
>>>stack>>>
3ffea680: 3ffe95f5 00000000 00000002 402011e0
3ffea690: 00000011 00000001 3ffe95ef 40201339
3ffea6a0: 00000007 3ffe95c8 3ffe95e1 3ffe95c8
3ffea6b0: 3ffe95c8 00000050 3ffe95e1 402056dc
3ffea6c0: 0000004c 0000004c 3ffe9598 40205702
3ffea6d0: 00500000 3ffe9598 3ffe9598 40204ae4
3ffea6e0: 0000000f 0000003f 3ffe9598 40205702
3ffea6f0: 3ffe9648 40100d43 000007d0 3ffea78c
3ffea700: 00500000 3ffe9598 40202cd8 40202823
3ffea710: 4020153a 000007d0 00000000 3ffea78c
3ffea720: 3fffdc20 00000000 3ffe9598 40202b40
3ffea730: 00000000 00000000 00000000 00000000
3ffea740: 3fffdc20 00000000 3ffea784 40201cbf
3ffea750: 00000000 00000000 3ffe9740 40100118
<<<stack<<<
I then loaded this library which is supposed to work with ESP8266. It got everything right up until when it tries to display a bitmap, when I got
Exception (3):
epc1=0x40205200 epc2=0x00000000 epc3=0x00000000 excvaddr=0x4022ea0c depc=0x00000000
ctx: cont
sp: 3ffea560 end: 3ffea770 offset: 01a0
>>>stack>>>
3ffea700: 3ffe965c 40100d43 000007d0 3ffe965c
3ffea710: 3fffdc20 3ffea79c 40201c4e 3ffe9750
3ffea720: 4020153a 000007d0 3ffe9598 3ffea79c
3ffea730: 00000001 4022ea0c 3ffe9598 40202c98
3ffea740: 00000001 00000000 00000000 00000000
3ffea750: 3fffdc20 00000000 3ffea794 40201cbf
3ffea760: 00000000 00000000 3ffe9750 40100118
<<<stack<<<
I tried this code on an Arduino Micro and it worked perfectly. I first thought that this was a memory issue, until I found this video that runs an SSD1306 with an ESP8266 just fine using the second library.
Any hints would be greatly appreciated. Thanks!
PS. On the example code, I got a problem with this bit:
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endifEven though I have fixed the .h file (#define SSD1306_128_64), it still gives me that error. Trying to print out the value of SSD1306_LCDHEIGHT gives me 64. So I'm not sure what the problem was and ended up commenting it out.
