- Sun Nov 16, 2014 10:21 am
#2735
tyleroderkirk wrote:I've uploaded the three firmware binaries to this Google Drive folder
Don't forget the flash the "webpages" binary as per the makefile or else you'll get "Magic mismatch. EspFS image broken."
-Tyler
I managed to flash it to my module, and I can access it as SoftAP (and blink an LED), but trying to scan wifi or associate to my network fails with a watchdog reset:
Code: Select allCon req, conn=0x3fff3eb0, pool slot 0
URL = /wifi/wifi.tpl
Is url index 8
Heatshrink compressed file; decode parms = b4
Con req, conn=0x3fff40a8, pool slot 1
URL = /wifi/style.css
Is url index 10
Conn 0x3fff40a8 is done. Closing.
Con req, conn=0x3fff42c0, pool slot 1
URL = /wifi/140medley.min.js
Is url index 10
Conn 0x3fff42c0 is done. Closing.
Con req, conn=0x3fff4250, pool slot 1
URL = /wifi/wifiscan.cgi
Is url index 7
Fatal exception (28):
epc1=0x402411a9, epc2=0x00000000, epc3=0x00000000, excvaddr=0x000000aa, depc=0x00000000
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x40100000, len 25492, room 16
tail 4
chksum 0xea
load 0x3ffe8000, len 2784, room 4
tail 12
chksum 0xa7
ho 0 tail 12 room 4
load 0x3ffe8ae0, len 5188, room 12
tail 8
chksum 0x7d
csum 0x7d
Httpd init, conn=0x3ffea198
Ready
mode : softAP(1a:fe:34:98:dd:8a)
add if1
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
bcn 100
add 1
aid 1
pm close 0 0 0/9495578
I also create an HTML form to directly invoke /wifi/connect.cgi, but that seems to redirect quickly to /wifi/wifi.tpl and run into the same problem.
I'm running the module off 5V off the USB bus, though a step-down converter rated at 10A, and have added 2x 1000µF plus one 100nF to the 3.3V line, so I think the supply should be sufficient.
Any suggestions?
EDIT: with the Electrodragon firmware V0.925, I can scan for APs and join without problems, so I'm pretty sure it's not the power supply.
