- Wed Dec 02, 2015 11:26 am
#35515
Hi,
I'm having trouble getting esp-ginx working reliably on my nodeMCU v0.9.
I've gone back to basics and have gone through the following steps:
1. Downloaded latest esp-ginx from github.
2. Changed esp-ginx makefile to point at my xtensa-lx106-elf/bin folder (from esp-open-sdk).
3. Successfully ran 'make clean', 'make html' and 'make'.
4. Tried uploading with esptool.py bundled with esp-ginx. Got following error:
Code: Select allConnecting...
Traceback (most recent call last):
File "../tools/esptool.py", line 387, in <module>
esp.connect()
File "../tools/esptool.py", line 155, in connect
raise Exception('Failed to connect')
Exception: Failed to connect
../Makefile:178: recipe for target 'flash' failed
After replacing this esptool.py with the latest from github, I can successfully flash the nodeMCU.
The output from the serial at /dev/ttyUSB0 is:
Code: Select allfound, reconnect after 1s
reconnect
f -180,
FREE HEAP: 36280
For reasons I don't understand, my serial terminal is cleared after this and the same message is printed again every couple of seconds.
I can see the AP SSID, but cannot connect to it. Once something seemed to happen where an HTTP request got through. I have put the serial output here:
http://pastebin.com/ZrZcrmHW. I'd already tried to browse to smart.relay.com previously and still had the browser open, so I guess this is why the request was made?
At the moment I can't get this example working, I'm rather stuck. Any help or advice would be much appriciated.
Thanks,
James
