So, I need some help with an IoT project im trying to build. I've successfully created a home automation system with esp8266 and a webserver. I'm using python and django for the webserver and the esp is connect with 8 channel relay. My issue is to be able to control a device with alexa. I did the example from sinric pro for a light and it turns on successfully. But when trying to merge the code from example and my code webserver + sinric pro doesnt not work together. Any ideas??
I'm ataching my code for this. The esp is connecting to the webserver under /home/get_relay_group_status and it's getting the json variables (r_status = false or true). I can also send merged code with sinric.
#include <ArduinoJson.h>
const char* ssid = "wifiname";
const char* password = "wifipass";
const int relay1 = 05; // GPIO05
const int relay2 = 04; // GPIO04
const int relay3 = 00; // GPIO00
const int relay4 = 02; // GPIO02
const int relay5 = 14; // GPIO14
const int relay6 = 12; // GPIO12
const int relay7 = 13; // GPIO13
const int relay8 = 15; // GPIO15
delay(4000);
WiFi.begin(ssid, password);
delay(1000);
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(relay5, OUTPUT);
pinMode(relay6, OUTPUT);
pinMode(relay7, OUTPUT);
pinMode(relay8, OUTPUT);
if ((WiFi.status() == WL_CONNECTED)) { //Check the current connection status
HTTPClient http;
http.begin("http://35.237.179.138//home/get_relay_group_status/"); //Specify the URL
int httpCode = http.GET(); //Make the request
if (httpCode > 0) { //Check for the returning code
const size_t capacity = JSON_ARRAY_SIZE(8) + 8 * JSON_OBJECT_SIZE(4) + 620;
DynamicJsonDocument doc(capacity);
char charBuf[capacity];
payload.toCharArray(charBuf, capacity);
deserializeJson(doc, charBuf);
JsonObject root_0 = doc[0];
bool root_0_r_status = root_0["r_status"];
JsonObject root_1 = doc[1];
bool root_1_r_status = root_1["r_status"];
JsonObject root_2 = doc[2];
bool root_2_r_status = root_2["r_status"];
JsonObject root_3 = doc[3];
bool root_3_r_status = root_3["r_status"];
JsonObject root_4 = doc[4];
bool root_4_r_status = root_4["r_status"];
JsonObject root_5 = doc[5];
bool root_5_r_status = root_5["r_status"];
JsonObject root_6 = doc[6];
bool root_6_r_status = root_6["r_status"];
JsonObject root_7 = doc[7];
bool root_7_r_status = root_7["r_status"];
if (root_0_r_status) {
Serial.println("Relay 1 is on ");
digitalWrite(relay1, LOW);
} else {
Serial.println("Relay 1 is off ");
digitalWrite(relay1, HIGH);
if (root_1_r_status) {
Serial.println("Relay 2 is on ");
digitalWrite(relay2, LOW);
} else {
Serial.println("Relay 2 is off ");
digitalWrite(relay2, HIGH);
if (root_2_r_status) {
Serial.println("Relay 3 is on ");
digitalWrite(relay3, LOW);
} else {
Serial.println("Relay 3 is off ");
digitalWrite(relay3, HIGH);
if (root_3_r_status) {
Serial.println("Relay 4 is on ");
digitalWrite(relay4, LOW);
} else {
Serial.println("Relay 4 is off ");
digitalWrite(relay4, HIGH);
if (root_4_r_status) {
Serial.println("Relay 5 is on ");
digitalWrite(relay5, LOW);
} else {
Serial.println("Relay 5 is off ");
digitalWrite(relay5, HIGH);
if (root_5_r_status) {
Serial.println("Relay 6 is on ");
digitalWrite(relay6, LOW);
} else {
Serial.println("Relay 6 is off ");
digitalWrite(relay6, HIGH);
if (root_6_r_status) {
Serial.println("Relay 7 is on ");
digitalWrite(relay7, LOW);
} else {
Serial.println("Relay 7 is off ");
digitalWrite(relay7, HIGH);
if (root_7_r_status) {
Serial.println("Relay 8 is on ");
digitalWrite(relay8, LOW);
} else {
Serial.println("Relay 8 is off ");
digitalWrite(relay8, HIGH);
else {
Serial.println("Error on HTTP request");
http.end(); //Free the resources
delay(10000);
