Re: OTA Flashing
Posted: Fri May 15, 2015 11:40 am
Thanks for the encouragement! Attached is another patch with a shell script to reflash the esp using curl. It's also added to the Makefile as 'make wiflash' assuming you have set the ESP_HOSTNAME in the makefile (or environment). The shell script takes care of uploading the correct partition and this set-up works quite well for me. I'll probably add a web page to manually upload the firmware, but this may take a few days. I don't really want to do it as long as I can't distinguish between user1.bin and user2.bin in the handler 'cause such as mix-up would be very uncool.
If you want to get started, you will need the SDK 1.0.1 (1.0.0 should also work), flash the boot_v1.3(b3).bin from the SDK's bin directory to 0x00000, flash blank.bin to 0x7E000, flash firmware/user1.bin to 0x01000, then connect to the AP and configure /wifi to hook up to your local AP. After that 'make wiflash' should reflash your puppy...
