# copyright (c) 2010 Espressif System
ifndef PDIR
endif
# Base directory for the compiler
XTENSA_TOOLS_ROOT ?= c:/Espressif/xtensa-lx106-elf/bin
# Select compile
ifeq ($(OS),Windows_NT)
# WIN32
# We are under windows.
ifeq ($(XTENSA_CORE),lx106)
# It is xcc
AR = xt-ar
CC = xt-xcc
NM = xt-nm
CPP = xt-cpp
OBJCOPY = xt-objcopy
#MAKE = xt-make
CCFLAGS += -Os --rename-section .text=.irom0.text --rename-section .literal=.irom0.literal
# It is gcc, may be cygwin
# Can we use -fdata-sections?
CCFLAGS += -Os -ffunction-sections -fno-jump-tables
AR = xtensa-lx106-elf-ar
CC = xtensa-lx106-elf-gcc
NM = xtensa-lx106-elf-nm
CPP = xtensa-lx106-elf-cpp
OBJCOPY = xtensa-lx106-elf-objcopy
endif
FIRMWAREDIR = ..\\bin\\
ifndef COMPORT
ESPPORT = com3
ESPPORT = $(COMPORT)
endif
ifeq ($(PROCESSOR_ARCHITECTURE),AMD64)
# ->AMD64
endif
ifeq ($(PROCESSOR_ARCHITECTURE),x86)
# ->IA32
endif
# We are under other system, may be Linux. Assume using gcc.
ifndef COMPORT
ESPPORT = /dev/ttyUSB0
endif
FIRMWAREDIR = ../bin/
UNAME_S := $(shell uname -s)
ifeq ($(UNAME_S),Linux)
# LINUX
endif
ifeq ($(UNAME_S),Darwin)
# OSX
endif
UNAME_P := $(shell uname -p)
ifeq ($(UNAME_P),x86_64)
# ->AMD64
endif
ifneq ($(filter %86,$(UNAME_P)),)
# ->IA32
endif
ifneq ($(filter arm%,$(UNAME_P)),)
# ->ARM
endif
endif
ESPTOOL ?= ../tools/esptool.py
MKFSTOOL ?= tools/mkfs.py
CSRCS ?= $(wildcard *.c)
ASRCs ?= $(wildcard *.s)
ASRCS ?= $(wildcard *.S)
SUBDIRS ?= $(patsubst %/,%,$(dir $(wildcard */Makefile)))
ODIR := .output
OBJODIR := $(ODIR)/$(TARGET)/$(FLAVOR)/obj
OBJS := $(CSRCS:%.c=$(OBJODIR)/%.o) \
$(ASRCs:%.s=$(OBJODIR)/%.o) \
$(ASRCS:%.S=$(OBJODIR)/%.o)
DEPS := $(CSRCS:%.c=$(OBJODIR)/%.d) \
$(ASRCs:%.s=$(OBJODIR)/%.d) \
$(ASRCS:%.S=$(OBJODIR)/%.d)
LIBODIR := $(ODIR)/$(TARGET)/$(FLAVOR)/lib
OLIBS := $(GEN_LIBS:%=$(LIBODIR)/%)
IMAGEODIR := $(ODIR)/$(TARGET)/$(FLAVOR)/image
OIMAGES := $(GEN_IMAGES:%=$(IMAGEODIR)/%)
BINODIR := $(ODIR)/$(TARGET)/$(FLAVOR)/bin
OBINS := $(GEN_BINS:%=$(BINODIR)/%)
CCFLAGS += \
-g \
-O2 \
-Wpointer-arith \
-Wundef \
-Werror \
-Wl,-EL \
-fno-inline-functions \
-nostdlib \
-mlongcalls \
-mtext-section-literals
# -Wall
CFLAGS = $(CCFLAGS) $(DEFINES) $(EXTRA_CCFLAGS) $(INCLUDES)
DFLAGS = $(CCFLAGS) $(DDEFINES) $(EXTRA_CCFLAGS) $(INCLUDES)
# Functions
define ShortcutRule
$(1): .subdirs $(2)/$(1)
endef
define MakeLibrary
DEP_LIBS_$(1) = $$(foreach lib,$$(filter %.a,$$(COMPONENTS_$(1))),$$(dir $$(lib))$$(LIBODIR)/$$(notdir $$(lib)))
DEP_OBJS_$(1) = $$(foreach obj,$$(filter %.o,$$(COMPONENTS_$(1))),$$(dir $$(obj))$$(OBJODIR)/$$(notdir $$(obj)))
$$(LIBODIR)/$(1).a: $$(OBJS) $$(DEP_OBJS_$(1)) $$(DEP_LIBS_$(1)) $$(DEPENDS_$(1))
@mkdir -p $$(LIBODIR)
$$(if $$(filter %.a,$$?),mkdir -p $$(EXTRACT_DIR)_$(1))
$$(if $$(filter %.a,$$?),cd $$(EXTRACT_DIR)_$(1); $$(foreach lib,$$(filter %.a,$$?),$$(AR) xo $$(UP_EXTRACT_DIR)/$$(lib);))
$$(AR) ru $$@ $$(filter %.o,$$?) $$(if $$(filter %.a,$$?),$$(EXTRACT_DIR)_$(1)/*.o)
$$(if $$(filter %.a,$$?),$$(RM) -r $$(EXTRACT_DIR)_$(1))
endef
define MakeImage
$$(IMAGEODIR)/$(1).out: $$(OBJS) $$(DEP_OBJS_$(1)) $$(DEP_LIBS_$(1)) $$(DEPENDS_$(1))
@mkdir -p $$(IMAGEODIR)
$$(CC) $$(LDFLAGS) $$(if $$(LINKFLAGS_$(1)),$$(LINKFLAGS_$(1)),$$(LINKFLAGS_DEFAULT) $$(OBJS) $$(DEP_OBJS_$(1)) $$(DEP_LIBS_$(1))) -o $$@
endef
$(BINODIR)/%.bin: $(IMAGEODIR)/%.out
@mkdir -p $(BINODIR)
$(ESPTOOL) elf2image $< -o $(FIRMWAREDIR)
# Rules base
# Should be done in top-level makefile only
all: .subdirs $(OBJS) $(OLIBS) $(OIMAGES) $(OBINS) $(SPECIAL_MKTARGETS)
clean:
$(foreach d, $(SUBDIRS), $(MAKE) -C $(d) clean;)
$(RM) -r $(ODIR)/$(TARGET)/$(FLAVOR)
clobber: $(SPECIAL_CLOBBER)
$(foreach d, $(SUBDIRS), $(MAKE) -C $(d) clobber;)
$(RM) -r $(ODIR)
flash:
ifndef PDIR
$(MAKE) -C ./app flash
$(ESPTOOL) --port $(ESPPORT) write_flash 0x00000 $(FIRMWAREDIR)0x00000.bin 0x10000 $(FIRMWAREDIR)0x10000.bin
endif
html:
$(MKFSTOOL) -s app/http/html/ -d app/http/rofs_data.c
.subdirs:
@set -e; $(foreach d, $(SUBDIRS), $(MAKE) -C $(d);)
#.subdirs:
# $(foreach d, $(SUBDIRS), $(MAKE) -C $(d))
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(MAKECMDGOALS),clobber)
ifdef DEPS
sinclude $(DEPS)
endif
endif
endif
$(OBJODIR)/%.o: %.c
@mkdir -p $(OBJODIR);
$(CC) $(if $(findstring $<,$(DSRCS)),$(DFLAGS),$(CFLAGS)) $(COPTS_$(*F)) -o $@ -c $<
$(OBJODIR)/%.d: %.c
@echo DEPEND: $(CC) -M $(CFLAGS) $<
@set -e; rm -f $@; \
$(CC) -M $(CFLAGS) $< > $@.$$$$; \
sed 's,\($*\.o\)[ :]*,$(OBJODIR)/\1 $@ : ,g' < $@.$$$$ > $@; \
rm -f $@.$$$$
$(OBJODIR)/%.o: %.s
$(CC) $(CFLAGS) -o $@ -c $<
$(OBJODIR)/%.d: %.s
@mkdir -p $(OBJODIR); \
set -e; rm -f $@; \
rm -f $@.$$$$
$(OBJODIR)/%.o: %.S
$(CC) $(CFLAGS) -D__ASSEMBLER__ -o $@ -c $<
$(OBJODIR)/%.d: %.S
set -e; rm -f $@; \
rm -f $@.$$$$
$(foreach lib,$(GEN_LIBS),$(eval $(call ShortcutRule,$(lib),$(LIBODIR))))
$(foreach image,$(GEN_IMAGES),$(eval $(call ShortcutRule,$(image),$(IMAGEODIR))))
$(foreach bin,$(GEN_BINS),$(eval $(call ShortcutRule,$(bin),$(BINODIR))))
$(foreach lib,$(GEN_LIBS),$(eval $(call MakeLibrary,$(basename $(lib)))))
$(foreach image,$(GEN_IMAGES),$(eval $(call MakeImage,$(basename $(image)))))
# Recursion Magic - Don't touch this!!
# Each subtree potentially has an include directory
# corresponding to the common APIs applicable to modules
# rooted at that subtree. Accordingly, the INCLUDE PATH
# of a module can only contain the include directories up
# its parent path, and not its siblings
# Required for each makefile to inherit from the parent
INCLUDES := $(INCLUDES) -I $(PDIR)include -I $(PDIR)include/$(TARGET)
PDIR := ../$(PDIR)
sinclude $(PDIR)Makefile
Moderator: Sprite_tm
Patriko wrote:I'd be thankfulI tried to use other Makefiles from DevKit examples but it deosn't work
i attached adapted project folder link for devkit. just put in workspace and import to the eclipse. also you can use prebuilded binaries in "bin" folder.
https://www.dropbox.com/s/75uprk1uz0uy1 ... x.zip?dl=0
Lets get the party started and +1
[url=https://www.banggood.com/custlink/KvGGhGF4wG[/url]
I like ESP8266 and ESP8285 and ESP32
