I need to save probably one or two lines of strings and integers permanently and retrieve them in the next power cycle. so removing power from esp should not delete the data.
Thanks in advance
Explore... Chat... Share...
Moderator: Sprite_tm
#define CONFIG_SECTOR 0x80-4 typedef struct {
uint32_t A;
char B[256];
} config;
spi_flash_erase_sector(CONFIG_SECTOR); #define CONFIG_ADDRESS = ( CONFIG_SECTOR * 4096 )spi_flash_write(CONFIG_ADDRESS ,(uint32 *)(some_config_pointer),sizeof(config));
spi_flash_read(CONFIG_ADDRESS ,(uint32 *)(some_config_pointer),sizeof(config));It takes about 20-25 seconds for home assistant c[…]
