Sming - Open Source framework for high efficiency native ESP8266 development
By j0hncc
#19252 Hi Nitrokart,
When you copy/paste to command line do you copy/paste exactly this? (Mainly the /opt/esp-open-sdk/esptool/esptool.py part)
Code: Select all/opt/esp-open-sdk/esptool/esptool.py -p /dev/tty.usbserial-A6008j9X -b 115200 write_flash 0x00000 out/firmware/eagle.flash.bin 0x9000 out/firmware/eagle.irom0text.bin 0x3C000 out/firmware/spiff_rom.bin
And it works?
Try these commands and reply what they say
Code: Select allwhich python
Code: Select allhead -1 /opt/esp-open-sdk/esptool/esptool.py
By nitrokart
#19258
j0hncc wrote:Hi Nitrokart,
And it works?
Yes when I run the esptool.py from the terminal it all works fine...
I runned the commands you told on terminal and on eclipse...
Terminal:
python -V
Python 2.7.10
which python
/Library/Frameworks/Python.framework/Versions/2.7/bin/python
#!/usr/bin/env python
Eclipse:
python -V
Python 2.7.6
which python
/usr/bin/python
Thanks
