Although when adding the function definition and the right linker specification to the application it can be used.
If you require specific SDK functions, feel free to mention them and if required by more they could be added to Sming
hreintke wrote:No, a SDK API function cannot be used directly in the sming framework.
Suppose I want to call
wifi_station_set_reconnect_policy(true)Not sure why but when I include the
wifi_station_set_reconnect_policy(true);
into an example application I can compile without errors.
Earlier usage of other sdk functions needed additional effort so there must be difference between sdk functions.
Can you try whether your application compiles and runs OK ?
If yes, I will further investigate why and which difference exist
