I'm trying to use the MPR121 touch sensor with Sming but am getting no where...... other than more confused
Would any of you good people be able to provide an example to get me going?
Thanks!
Explore... Chat... Share...
jmccoy555 wrote:So, it turns out to be quite easy once you know how!!!
1. Download, extract and put the Adafruit library in the Sming/Libraries folder
2. I had to change line 87 from __attribute__((deprecated)) void setThreshholds(uint8_t touch, uint8_t release); to void setThreshholds(uint8_t touch, uint8_t release);
3. Remake sming (wasn't an obvious step to me until I though about it, make clean - make - make spiffy
4 Cobble together some code based on the Arduino example (not sure if its 100% accurate and correct but it works!);
Hope that helps someone out! I guess it would be similar for other libraries too.
