WIFI AP + WEB Server
PostPosted: Thu Oct 19, 2017 3:53 am
by Arnost
Hello,
I needed to combine these two codes, one can create an AP and the other one can create a Web server, unfortunately I do not know how to merge the codes to make it work at the same time.
Code: Select all/*
Arduino Due - ESP 8266 WiFi Module
Serial (Tx/Rx) communicate to PC via USB
Serial3 (Tx3/Rx3) connect to ESP8266
Tx3 - ESP8266 Rx
Rx3 - ESP8266 Tx
ESP8266 CH_PD Connect to ESP8266 VCC
#define ASCII_0 48
#define ESP8266 Serial3
String SSID = "MojeWifi";
String PASSWORD = "123456789";
int LED = 13;
boolean FAIL_8266 = false;
String strHTML;
String strHTMLstart = "<!doctype html>\
<html>\
<head>\
<title>";
String strHTMLend ="</title>\
</head>\
<body>\
<H1>Ahoj Lidi</H1>\
</body>\
</html>";
void htlmcode(){
  strHTML = "";
  strHTML = strHTML + millis() + strHTMLend;
boolean cwJoinAP()
  String cmd="AT+CWJAP=\"" + SSID + "\",\"" + PASSWORD + "\"";
  ESP8266.println(cmd);
  return waitOKfromESP8266(10);
  pinMode(LED, OUTPUT);
  do{
    ESP8266.begin(115200);
    //Wait Serial Monitor to start
    while(!Serial);
    Serial.println("--- Start ---");
    ESP8266.println("AT+RST");
    delay(1000);
    if(ESP8266.find("ready"))
      Serial.println("Module is ready");
      ESP8266.println("AT+CWMODE=1");
      delay(2000);
      //Quit existing AP, for demo
      Serial.println("Quit AP");
      ESP8266.println("AT+CWQAP");
      delay(1000);
      clearESP8266SerialBuffer();
      if(cwJoinAP())
        Serial.println("CWJAP Success");
        FAIL_8266 = false;
        delay(3000);
        //Get and display my IP
        sendESP8266Cmdln("AT+CIFSR", 1000);
        //Set multi connections
        sendESP8266Cmdln("AT+CIPMUX=1", 1000);
        //Setup web server on port 80
        sendESP8266Cmdln("AT+CIPSERVER=1,80",1000);
        Serial.println("Server setup finish");
      }else{
        Serial.println("CWJAP Fail");
        FAIL_8266 = true;
    }else{
      Serial.println("Module have no response.");
      delay(3000);
      FAIL_8266 = true;
  }while(FAIL_8266);
  digitalWrite(LED, HIGH);
void loop(){
  if(ESP8266.available())
    Serial.println("Something received");
    delay(1000);
    if(ESP8266.find("+IPD,"))
      String action;
      Serial.println("+IPD, found");
      int connectionId = ESP8266.read()-ASCII_0;
      Serial.println("connectionId: " + String(connectionId));
      htlmcode();
      sendHTTPResponse(connectionId, strHTML);
      //Close TCP/UDP
      String cmdCIPCLOSE = "AT+CIPCLOSE=";
      cmdCIPCLOSE += connectionId;
      sendESP8266Cmdln(cmdCIPCLOSE, 1000);
void sendHTTPResponse(int id, String content)
  String response;
  response = "HTTP/1.1 200 OK\r\n";
  response += "Content-Type: text/html; charset=UTF-8\r\n";
  response += "Content-Length: ";
  response += content.length();
  response += "\r\n";
  response +="Connection: close\r\n\r\n";
  response += content;
  String cmd = "AT+CIPSEND=";
  cmd += id;
  cmd += ",";
  cmd += response.length();
  Serial.println("--- AT+CIPSEND ---");
  sendESP8266Cmdln(cmd, 1000);
  Serial.println("--- data ---");
  sendESP8266Data(response, 1000);
boolean waitOKfromESP8266(int timeout)
  do{
    Serial.println("wait OK...");
    delay(1000);
    if(ESP8266.find("OK"))
      return true;
  }while((timeout--)>0);
  return false;
//Send command to ESP8266, assume OK, no error check
//wait some time and display respond
void sendESP8266Cmdln(String cmd, int waitTime)
  delay(waitTime);
//Basically same as sendESP8266Cmdln()
//But call ESP8266.print() instead of call ESP8266.println()
void sendESP8266Data(String data, int waitTime)
  ESP8266.print(data);
  delay(waitTime);
//Clear and display Serial Buffer for ESP8266
void clearESP8266SerialBuffer()
  Serial.println("= clearESP8266SerialBuffer() =");
  while (ESP8266.available() > 0) {
    char a = ESP8266.read();
    Serial.write(a);
  Serial.println("==============================");
Second code:
Code: Select allchar ssid[] = "ssid-site"; //SSID wifi sítě
char pwd[] = "heslo-site"; //heslo sítě
String cmd; //řetězec pro ukládání a skládání příkazů
String http;
void setup(){
Serial3.begin(115200); //9600, 57600, 115200
cmd = "AT";
command(cmd, "Zkousim pritomnost modulu", "Modul komunikuje",
"Modul nekomunikuje", "OK", 3000);
cmd = "AT+RST";
command(cmd, "Restartuji modul", "Modul restartovan", "Modul se nepovedlo restartovat", "ready", 5000);
cmd = "AT+CIPMUX=1";
command(cmd, "Nastavuji vicenasobne pripojeni", "Nastaveno", "Nepovedlo se nastavit", "OK", 1000);
cmd = "AT+CWMODE=3";
command(cmd, "Nastavuji AP mod", "Nastaveno", "Nepovedlo se nastavit", "OK", 2000);
cmd = "AT+CWSAP=\"ESP-WIFI\",\"12345678\",8,3";
command(cmd, "Vytvarim pristupovy bod", "Vytvoreno", "Nepovedlo se vytvorit pristupovy bod", "OK", 3000);
cmd = "AT+CIPSERVER=1,80";
command(cmd, "Vytvarim server", "Vytvoreno", "Nepovedlo se vytvoritserver", "OK", 2000);
cmd = "AT+CIFSR";
command(cmd, "Zjistuji aktualni adresu", "", "", "", 2000);
void loop(){
if(waitFor("+IPD", 50)){ //hledej výskyt +IPD
Serial3.parseInt(); //jedno číslo zahoď
Serial3.parseInt(); //druhé číslo zahoď
int p = Serial3.parseInt(); //přečti třetí číslo
Serial.print("Nacetl jsem: ");
Serial.println(p);
Serial3.flush(); //zbytek zpravy me ted nezajima, zahod ho
resendData();
boolean command(String cmd, String comment, String success, String
unsuccess, char *waitForString, long waitingTime){
Serial.println(comment);
Serial.println("] " + cmd);
Serial3.println(cmd);
boolean result = waitFor(waitForString, waitingTime);
if(result){
Serial.println("[ " + success);
else{
Serial.println("[ " + unsuccess);
resendData();
return result;
boolean waitFor(char *s, long waitingTime){
Serial3.setTimeout(waitingTime);
return Serial3.find(s);
boolean resendData(){
while(Serial.available()){
Serial3.write(Serial.read());
if(Serial3.available()){
while(Serial3.available()){
Serial.write(Serial3.read());
