Json datas not display all data-two function only on working
Posted: Fri Mar 05, 2021 2:17 am
Hi, I use two same javascript function I change just the variable and name to display datas on my webpage.
The first function is working but not the second.
On the browser I receive this error:
The function refreshSoilHumidity working, I see the data on page.
The function refreshSolenoid dosen't working.
the ending of my first working function
the ending of my second not working function
The full code you can see here: https://pastebin.com/raw/3qUB04z4
How to send all datas on the correct way ?
Uncaught SyntaxError: Unexpected token O in JSON at position 6
at JSON.parse (<anonymous>)
at XMLHttpRequest.xmlhttp.onreadystatechange ((index):64)
<p><span id="t0"></span><span id="s0"></span></p>
<p><span id="t1"></span><span id="s0"></span></p>
<p><span id="t2"></span><span id="s2"></span></p>
<p><span id="t3"></span><span id="s3"></span></p>
<p><span id="t4"></span><span id="s4"></span></p>
<script type="text/javascript">
refresh();
setInterval(refresh, 1000);
function refresh(){
refreshSoilHumidity();
refreshSolenoid();
refreshPump();
function refreshSoilHumidity(){
var xmlhttp = new XMLHttpRequest();
xmlhttp.onreadystatechange = function() {
if (xmlhttp.readyState == XMLHttpRequest.DONE && xmlhttp.status == 200){
const parsedData = JSON.parse(xmlhttp.responseText);
document.getElementById("t0").innerHTML = "SoilHumidity Sensor 0: " + parsedData.t0 + "%";
document.getElementById("t1").innerHTML = "SoilHumidity Sensor 1: " + parsedData.t1 + "%";
document.getElementById("t2").innerHTML = "SoilHumidity Sensor 2: " + parsedData.t2 + "%";
document.getElementById("t3").innerHTML = "SoilHumidity Sensor 3: " + parsedData.t3 + "%";
document.getElementById("t4").innerHTML = "SoilHumidity Sensor 4: " + parsedData.t4 + "%";
xmlhttp.open("GET", "/SoilHumidity", true);
xmlhttp.send();
function refreshSolenoid(){
document.getElementById("s0").innerHTML = "Solenoid0 State 0: " + parsedData.s0;
document.getElementById("s1").innerHTML = "Solenoid1 State 1: " + parsedData.s1;
document.getElementById("s2").innerHTML = "Solenoid2 State 2: " + parsedData.s2;
document.getElementById("s3").innerHTML = "Solenoid3 State 3: " + parsedData.s3;
document.getElementById("s4").innerHTML = "Solenoid4 State 4: " + parsedData.s4;
xmlhttp.open("GET", "/Solenoid", true);
xmlhttp.send();
function refreshPump(){
document.getElementById("pumpState").innerHTML = "Pump State: " + this.responseText;
xmlhttp.open("GET", "/pump", true);
xmlhttp.send();
</script>
String json = "{\"t0\":" + String(sensor0) + ",\"t1\":" + String(sensor1)+ ",\"t2\":" + String(sensor2)+ ",\"t3\":" + String(sensor3)+ ",\"t4\":" + String(sensor4)+ "}";
server.send (200, "application/json", json);
String json1 = "{\"s0\":" + String(solenoidState0) + ",\"s1\":" + String(solenoidState1)+ ",\"s2\":" + String(solenoidState2)+ ",\"s3\":" + String(solenoidState3)+ ",\"s4\":" + String(solenoidState4)+ "}";
server.send (200, "application/json", json1);
