Page 1 of 5
New help file format. Addition of UDP commands from Cicciocb
PostPosted: Sat Apr 02, 2016 5:33 pm
by Mmiscool
Hello.
There have been several good changes to ESP BASIC over the past few months. At this point I believe things are stabilizing a bit in the new 2.0 alpha releases. There will be some slight changes to the syntax of some of the commands going forward but for now it seems that we have a good working version. Once there is a bit more feed back on the latest build I think it will move to being beta.
See the new UDP commands Cicciocb added here
http://www.esp8266basic.com/language-re ... f9gnk1rfei
UDP allows for very fast esp to esp or esp to pc communication for purposes of sending commands and feed back.
Re: New help file format. Addition of UDP commands from Cicc
PostPosted: Mon Apr 04, 2016 4:18 am
by Electroguard
The list of new commands is a great help.
Seeing as the commands list will likely be an important reference for people, it might be better to avoid confusion by not adding the colon after each listed command. For similar reasons it might be an idea to add an initial explanation that the use of curly braces in the help explanations is not actually part of the commands syntax.
PostPosted: Mon Apr 04, 2016 4:51 am
by Electroguard
For commands whose sysntax has changed from V1xx to V2 like the print commands now using the "&" concatenation character, it might be worth including both old and new syntaxs together with either the old or new highlighted in different a colour.
PostPosted: Wed Apr 06, 2016 5:12 pm
by Electroguard
Just a minor typo for the instr() entry that I noticed...
instr():
Will return location of a sub string within a string.
len({string or var name},{string or var name to locate})
