- Wed May 04, 2016 7:36 pm
#46902
Hi Mike, your user manual is getting rather large compared to early on. This is a good thing and very much appreciated. The only suggestion I can give is if there can be an example or two of using each command as the syntax is not clear to noobs like me.
For instance...
timesetup():
Will set up the time time zone and daylight savings attribute.
timesetup({number or var for time zone},{number or var for dst})
(this next part would be great after the above statement)
EXAMPLE USE OF COMMAND:
timesetup(-5,0)
what does the -5 do and what does the 0 do? What can be used for dst, is it 0 for DST or 1 for DST, etc...
This is a simple example (even though I still don't know what the number or var for dst does or what it needs to be. This type of info is invaluable for someone to grab the docs and get up and running without having to visit the forum to see if someone used a snippet of code so you can see how to format it, etc.
Not bitching at all, but this would really help in a big way.
I really do appreciate your efforts with this. I had a few esp8266s laying around for a while after I gave up playing with the AT command set and dealing with the constant busy_s error and crashes. Now I have a few doing things I never thought would be possible solely because I can wrap my head around basic. I have plans for some incoming Wemos mini D1s and it just keeps getting better and better. The capabilities are outstanding.
MANY THANKS!!!
EDIT...
One quick thing I noticed was something you just recently posted in the general section.
html "display changing data here " & htmlvar(data)
I can't find any information on the "html" command in the manual, it may be there, but I haven't found it so forgive me if I am wrong.
The question is, when would you use the "html" command instead of the "wprint" command. Is there a difference between the two?
Thanks again.
