- Sun Jul 03, 2016 1:29 pm
#50135
I know this may suck but it is the shortest possible version of what I am doing more greater than 20 lines.
Brief explanation:
It essentially spits out web page responses needed for my phone application the html code is just for a black background and green text as well as appropriate spacing and done in a manner that tracks pin status each time an operation is completed. I like to start off as having the variable on in the event that there is a power outage the device turns back on. I am using a fan and a relay for hardware.
Now there have been variations on how to do this through the versions that 1.x you could do it one way but this did not work for 2.x so I found another way in version 3.x I have not found a possible variation.
In any event this is a great feature to lose the ability to display different web pages built with msgbranch extends far beyond my little example given here one can only dream up possibility here it is nearly endless.
Bare with me this is long and I apologize for the length of it! Just humor me please.
I suggest you select this all and paste it to notepad for better reading:
NOTE THE CODE I TRIED TO ADD BOLD TAGS TO With an arrorow <------------------ is the difference between the operation in 1.x and 2.x as far as 3.x I have not gotten it to work correctly could be something dumb I am not aware of in 3.x but if so it is likely not documented well and it may be helpful to have it documented.
Also Code has been created for all 3 versions noting the differences between versions!
Code: Select all
v1 code
Let 12SX = 1
msgbranch [mybranch]
cls
print "<html><head></head><text><body bgcolor=000000 text=C6ED2C><center>SERVER STATUS=200 OK "
Wait
[mybranch]
cls
MyReturnMsg = "Not a valid msg received"
msgget "pin" pinNo
msgget "stat" pinStatus
msgget "action" pinAction
if pinAction == "po" then gosub [pomypin]
if pinAction == "s" then gosub [readmyit]
cls
print "SERVER: 200 STATUS OK </body></center></html>"
msgreturn myreturnmsg
wait
[pomypin]
cls
po pinNo pinStatus
if pinNo == "12" then 12SX = pinStatus [b]'<------------- This line tracks variables fine in 1.x versions!!!![/b]
if pinNo == "12" then OL = "<html><head></head><text><body bgcolor=000000 text=C6ED2C><center><p>.</p>FAN1"
myreturnmsg = ""
if pinStatus = 1 then myreturnmsg = OL & ": was turned OFF successfully </body></center></html>" else MyReturnMsg = OL & ":
was turned ON successfully</body></center></html>"
return
[readmyit]
cls
let myreturnmsg = ""
myreturnmsg = myreturnmsg & "<html><head></head><text><body bgcolor=000000 text=C6ED2C><center>"
myreturnmsg = myreturnmsg & ".:: FAN1 Status ::.<p></p><p></p>"
if 12SX = 1 then myreturnmsg = myreturnmsg & "<p>UNIT: ON</p></body></center></html>" else myreturnmsg = myreturnmsg &
"<p>UNIT: OFF</p></body></center></html>"
return
Version 2 Code you could no longer use this line of code to track things beyond the first tracking: if pinNo == "12" then 12SX =
pinStatus
So below is the workaround code!
Let 12SX = 1
cls
Wait
[mybranch]
cls
myretunmsg = "Not a valid msg received"
msgget "pin" pinNo
cls
wait
[pomypin]
cls
po pinNo pinStatus
if pinno == "12" then 12SX = io(laststat,12) [b]'<----------------This line fixed something that changed in the ability to consistantly track [/b]
variables!!!!!
myreturnmsg = ""
if pinStatus = 1 then myreturnmsg = OL & ": was turned OFF successfully </body></center></html>" else myretunmsg = OL & ": was
return
[readmyit]
cls
return
V3 Code DONT WORK at all even using your latest example I cannot build web page response from code possibly it is my own error
IDK but this is why I post and keep trying!
let 12SX = 1
io(po,12,1)
cls
wprint "<html><head></head><text><body bgcolor=000000 text=C6ED2C><center>SERVER STATUS=200 OK "
wait
[mybranch]
cls
pinno = val(msgget("pin"))
pinstatus = val(msgget("stat"))
pinaction = msgget("action")
if pinaction == "po" then gosub [pomypin]
if pinaction == "s" then gosub [readmyit]
cls
wprint "Sever: 200 OK </body></center></html>"
wait
[pomypin]
cls
io(po,pinno,pinstatus)
if pinno == "12" then OL = "<html><head></head><text><body bgcolor=000000 text=C6ED2C><center><p>.</p>FAN1"
if 12SX = 1 then myreturnmsg = OL & ": was turned ON successfully </body></center></html>" else myreturnmsg = OL & ": was
turned OFF successfully</body></center></html>"
return
[readmyit]
cls
return
'These are the Commands I use
'Commands Below
'On1
'http://LOCAL IP/msg?pin=12&stat=1&action=po This displays a page showing Fan turned on successfully
'Off1
'http://LOCAL IP/msg?pin=12&stat=0&action=po This displays a page showing Fan turned off successfully
'Status
'http://LOCAL IP/msg?action=s This displays a page showing if the fan is OFF or ON AKA status page.
Now if you take the time to notice there have been larger differences in how msgbranch works than you think and without appropriate testing of the versions and each of these codes you will not likely be able to distinguish the difference.
The bummer is these were not my actual working codes but I made them in a fashion to hopefully resemble as closely as to what I was doing to shorten things up substantially and I hope that in the process I did not mistype something. If I did my apologies! But I tried to make them as simplistic as possible green text black background full html page responses for each action and pin tracking.
I hope this helps I know it is a huge thing to ask but I really need to confirm things are changing and it is not just me causing problems I've tried to get version 3.x to work and it gives me No Message Branch Defined or something along that line.
