So I've conjured up a little code to solve that problem and have it working locally. While there are various ways one might check for connection to a router, I'm going simple. I just look to see if the WGET() that I use to report to my web server is returning a response. If it fails three times in an many minutes, I assume that I've lost connection with the router. While it could be other problems, those cannot be solved by the node and a re-connection is harmless.
' Initialize this once
fail = 0
' Timer triggered reporting code goes here to create a url with command line variable passage.
' (Once per minute in my case)
rv = wget(url)
if rv == "" then
fail = fail + 1
if fail>2 then gosub [reconnect]
endif
wait
[reconnect]
dim c_inf(6) as string
c_inf(1) = read("WIFIname")
c_inf(2) = read("WIFIpass")
c_inf(3) = read("ipaddress")
c_inf(4) = read("gateway")
c_inf(5) = read("subnetmask")
if c_inf(3) == "" then wifi.connect(c_inf(1),c_inf(2)) else wifi.connect(c_inf(1),c_inf(2),c_inf(3),c_inf(4),c_inf(5))
undim c_inf
fail = 0
returnSo this works by reading the router SSID and password and any IP setup from flash (same variables used in the Settings page). Then it uses the right version of the WIFI.CONNECT() function to re-connect. Notice how I use an array so I can DIM and UNDIM it to save on variables? Yeah, that means I read the flash variables every time, but speed is not an issue here.
Now all I have to do is get my cousin (who is barely computer literate) over to the house and talk him through updating the Basic program.
