Original Article about: WIFI Dev Board for Home Automation - Software example
Available on Tindie: https://www.tindie.com/products/nEXT_EVO1/universal-ac-mains-dimmer-mpdmv41/
Explore... Chat... Share...
Electroguard wrote:Looks like a well thought out design with a clean and simple software interface which is readily customisable.
One possibility for improvement which shouldn't add too much cost but could remove the need for your cautionary indicator explanation, might be to use bi-colour leds as indicators to display RED for ON and GREEN for OFF. Is a bit rich for my pocket anyway I'm afraid, but is a very nice job TrackerJ, which I hope brings success... and it's also good to see Mmiscool's brilliant Esp_Basic gain some deserving commercial street cred.
