print version()
load "\uploads\blink.bas"
print ip()
print id()Output:
ESP Basic 3.0.Alpha 66
Loading . . . . \uploads\blink.bas
Done...Explore... Chat... Share...
print version()
print ip()
print id()ESP Basic 3.0.Alpha 66
Done...Mmiscool wrote:Get rid of the leading slash ...
' https://www.esp8266basic.com/blink-example.html
' This will prompt the user to select the pin, blink duration and number of blinks to execute.
' GPIO 2 is normally connected to an LED on the nodemcu boards.
noOfBlinks = 0
pin = 0
blinkDelay = 1000
[top]
print "How many times to blink"
textbox noOfBlinks
print "Pin To use"
textbox pin
print "Blink Delay"
textbox blinkDelay
button "Blink Me Please", [blinkMe]
button "Exit", [getMeOutOfHere]
wait
[blinkMe]
for x = 1 to noOfBlinks
io(po,pin,1)
delay blinkDelay
io(po,pin,0)
delay blinkDelay
next x
wait
[getMeOutOfHere]
endIt takes about 20-25 seconds for home assistant c[…]
