BASIC
msgbranch [mybranch]
print "You can send msgs to the esp and do things based on accessing a URL"
wait
[mybranch]
MyReturnMsg = "Not a valid msg received"
pinStatus = val(msgget("stat"))
io(pwo,5,pinStatus)
MyReturnMsg = "200"
msgreturn MyReturnMsg
waitHTML/Javascript [upload to esp as index.htm]
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>toggle test</title>
<script src="http://192.168.4.1/file?file=jquery.js"></script>
<script type="text/javascript">
var dimmer
window.onload = function() {
var dimmer = 1024,
html = '<li>Dimmer Value: \
<input type="range" min="0" max="' + dimmer + '" value="'+dimmer+'" name="dimmer_value" id="dimmer_value" />\
<span>' + dimmer + '</span>\
</li>';
$("body").append(html);
$('#dimmer_value').on("input change", function() {
$(this).next().html($(this).val());
dimmer = "http://192.168.4.1/msg?stat=" + $(this).val();
console.log(dimmer);
$.ajax({
url: dimmer,
async: false }).done(function( data ) {
console.log(data); //or whatever
</script>
</head>
<body>
</body>
</html>Just browse to ESP_!P_ADDR/file?file=index.htm
I copied jquery onto the esp, not necessary if you don't intend to run the ESP in AP mode. I had to add a callback to the javascript otherwise the ESP gets inundated with request's and crashes. I tried to use multiple variables i.e wget "http://192.168.4.1/msg?pin=2&stat=1&action=po" -q -O - but again the ESP could not keep up and crashed. With one variable I could move the slider as much and as fast as I could.
I am making a RC car based off ESP8266 BASIC you can follow my progress here https://www.youtube.com/channel/UCXsnD8s75AEswtePX7EJmRA NOT MONETIZED This project is under Multi Episode Projects (wifi anything)
