Program:
dev = "ESP1"
st = 0
p = 2
Pi p st
print "ESP ist waiting for Pin " & p & " to change..."
interrupt p [gpio]
Wait
[gpio]
Pi p nst
if nst = 0 then
url = "192.168.178.23/esp/pin.php?Action=Message&mfrom=" & dev & "&mto=System&mtype=1&mess=Door/Window opened"
gosub [urlencode]
print wget(url)
url = "192.168.178.23/esp/pin.php?Action=Message&mfrom=" & dev & "&mto=System&mtype=2&mess=Door/Window closed"
gosub [urlencode]
print wget(url)
end if
st = nst
wait
[urlencode]
url = replace(url," ", "+")
print url
returnPHP:
<?php
$host = "127.0.0.1";
$user = "homeauto";
$pw = "homeauto";
$db = "HomeAuto";
$con = mysqli_connect($host,$user,$pw) or die(mysqli_error());
mysqli_select_db($con,$db) or die(mysqli_error());
mysqli_query($con,"SET CHARACTER SET utf8");
mysqli_query($con,"SET NAMES 'utf8'");
$action=$_GET["Action"];
switch ($action) {
Case "Message":
$mfrom=$_GET["mfrom"];
$mto=$_GET["mto"];
$mtype=$_GET["mtype"];
$mess=$_GET["mess"];
$r = mysqli_query($con, "Insert into mess (st, mfrom, mto, mtype, mess) VALUES ('I', '$mfrom', '$mto', '$mtype', '$mess')") or die(mysqli_error());
print $mess . "OK";
break;
Case "GetMessages":
$q = mysqli_query($con,"SELECT * FROM mess where mtype = '1' order by ts desc") or die(mysqli_error());
$rows = array();
while($r = mysqli_fetch_assoc($q))
$rows[] = $r;
$jsrows=json_encode($rows);
print $jsrows;
break;
default:
print json_encode ("Error: Function not defined ->" . $action);
?>MySQL table:
CREATE TABLE `mess` (
`nr` int(11) NOT NULL,
`st` varchar(200) COLLATE utf8_unicode_ci NOT NULL,
`ts` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ON UPDATE CURRENT_TIMESTAMP,
`mfrom` varchar(150) COLLATE utf8_unicode_ci NOT NULL,
`mto` varchar(150) COLLATE utf8_unicode_ci NOT NULL,
`mtype` varchar(200) COLLATE utf8_unicode_ci NOT NULL,
`mess` varchar(2000) COLLATE utf8_unicode_ci NOT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci;Wiring (Pin D4 -> GPIO2):
Add a password if you like to protect it from beeing called by anyone else than you.
