By joeman2116
#70715 Luc,
I ran the test program and also the debug mode
When i tell google to turn on living - nothing happens except google saying he has done the command.
When i open a browser and issue:
http://radxx.no-ip.ca:8086/msg?saywhat=living.room.on
or
http://174.xxx.xx.241:8086/msg?saywhat=living.room.on
The test program responds with living room on[/b
This verifies the port forwarding and ip are correct
[b]I My iftt applet:
Say a phrase with a text ingredient
switch the living room $
please turn the living room $
webhook content :
Make a web request - Fields which i filled
http://174.xxx.xx.241:8086 /msg?saywhat=living.room. {{TextField}} have verified the ip
Method GET
Content Type TEXT/PLAIN
I have deleted and recreated both iftt and web hooks several times with no change.
Webhooks is not sending out
As far as i can see google hears me, answers, but does not appear to be triggering webhooks web request.
Or
webhooks is not sending out my web request.
When i tell iftt to check applet - no errors
Applet ran
Oct 08 - 10:46 AM
Google Assistant
googlehome esp8266test
off
Hide details
Ingredients
CreatedAt
(none)
TextField
off
Thanks
Joe
By Luc Volders
#70718
Code: Select allThe test program responds with living room on[/b
I presume the [/b is not included and is a typo.......
And does it work ???
Does it indeed switch the light on ????
Giving the command from the browser should do something....
Code: Select allhttp://174.xxx.xx.241:8086 /msg?saywhat=living.room. {{TextField}}
I see a space between room. and {{TextField}} I hope that is not there in real life....
Luc
By joeman2116
#70729 The test program responds with living room on
I presume the [/b is not included and is a typo....... it was a typo
Sorry Yes it works fine , led goes on and off whenever I enter
http://174.xxx.xx.241:8086 /msg?saywhat=living.room.{{TextField}} in my browser
No, there is no space
joe
By Luc Volders
#70932 Hey Joe,
Did you get it working ??
I tested my setup again and checked against the writeup and found no mistakes and everything works here flawlessly.
Now one last thing.
I saw this:
Code: Select allhttp://radxx.no-ip.ca:8086/msg?saywhat=living.room.on
or
Maybe the radxx.no-ip thing does not work.
Try to replace it with your real-world IP adress. You can find that by looking at:
http://www.whatsmyip.org/
Maybe that's the problem.
Luc
