The code is in V3 A39.
I have started to work on a simple temperature control program which turns off / on a relay and sends a udp code to turn on /off a slave esp relay.
I had it working well in V2 but only until recently could I make it work on V3 .
The code is for a simple Master ESP. - which is working ok
Picture attached.
I am looking for some simple UDP based slave code
The master code is made up from pieces of code found thru out the forum and some stuff I added .
Thanks to coders like Electroguard and many others, there are some very elaborate examples of udp master slave controlling. Amazing network stuff!
However, I am looking for help to develop the simplest Slave code to have the master esp turn on or off an esp slave relay.
The overall aim is to provide a working example for a simple esp master / slave control V3 application .
Once it is working , it should help users, and provide a working example for a real world application..
A simple foundation to build on.
I believe the Master code udpwrite commands ok . The code controls a relay depending on temperature setting. It works..
1. In master esp - the setp code in the textbox setp , where the temperature is set. The space allocated for input is to long. I only wish to have around 6 digit spacing at best.
Does anyone have a solution to have it allocate less input space??
2. Esp slave coding - anyone have a simple solution?
MASTER CODE:
'ESPBASIC V32 A39 MASTER STAT B with slave control
'DB1820S Temp Sensor Data PIN IS D4
'Pin D2 for led or relay output inside
'Pin D5 for led or relay output outside
memclear
cls
let tf = 0
let curr = 0
let outc = 0 'for second temp sensor
setp = 22
settemp = 22
let stat = On
let statout = On
let setpout = 22
cssclass "button", "background-color: #99e6e6;"
cssclass "align-self: center;"
wprint "<head>"
wprint "<meta http-equiv='refresh'content='5;URL=/input?'>"
wprint "</head>"
wprint "<body bgcolor='#527a7a'>"
wprint "<table align='center' width='150' bgcolor='lightblue' border='6' cellpadding='5'>"
wprint "<th><b>MASTER Stat B</b></th>"
wprint "<th</th></table><br>"
wprint "<table align='center' width='180' bgcolor='lightblue' border='4' cellpadding='5'>"
wprint "<td>"
Button " 5 SECOND FAN TEST", [fon2]
wprint "</td>"
wprint "<table align='center' width='185' bgcolor='lightblue' border='4' cellpadding='3'>"
wprint "<td>"
wprint "<b>A/C ASSIST Fan-<b/>"
wprint "<mark>"
wprint htmlvar(stat)
wprint "</mark>"
wprint "<br>"
wprint "</td>"
wprint "<th</th></table>"
wprint "<br>"
wprint "<table align='center' width='330' bgcolor='#00cca3' border='5' cellpadding='5'>"
wprint "<td>"
Button "Set A/C ASSIST",[setpt]
textbox setp
wprint "<br>"
wprint "<table align='center' width='250' bgcolor='LIGHTBLUE' border='5' cellpadding='6'>"
wprint "<td>"
wprint "<b>A/C VENT TEMP= <b/>"
wprint htmlvar(curr)
wprint "(C)"
wprint "</td>"
wprint "<table align='center' width='250' bgcolor='#00ace6' border='5' cellpadding='5'>"
wprint "<td>"
wprint htmlvar(tfout)
wprint "(F)"
wprint "</td>"
'wprint "<br>"
wprint "<table align='center' width='60' bgcolor='lightblue' border='4' cellpadding='5'>"
wprint "<td>"
Button " exit", [quit]
wprint "</td>"
timer 4000, [refresh]
wait
[on2] ' FIRST SENSOR DB1820S ---------
io(po,d5,1)
let stat = "ON"
udpwrite "192.168.1.213", 5001, "ON" 'SEND UDP COMMAND TO SLAVE 192.168.1.213 RELAY D5 "ON"
wait
[off2] ' FIRST SENSOR DB1820S ---------
io(po,d5,0)
let stat = "OFF"
udpwrite "192.168.1.213", 5001, "OFF"
wait
[fon2] ' TEST FAN ON ----------
io(po,d5,1)
let stat = "ON"
wait
[setpt]
wprint "<head>"
wprint "<meta http-equiv='refresh' content='5;URL=/input?'>"
wprint "</head>"
wait
[refresh]
curr = temp(1) 'curr ' read current temperature for device 1 db1820 SECOND SENSOR
outc = temp(0) ' outc ' read current temperature for device 0 db1820 FIRST SENSOR
tf = curr * 9 ' Fahrenheit CONVERSON
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
if curr < setp then goto [on2] else goto [off2] 'FAN ON IF CURRENT TEMP < GREATER THEN SETP
wait
[outcon] ' second db1820s sensor TURN RELAY D5 ON AND STAT ON
io(po,d5,1)
let statout = "ON"
wait
[outcoff] ' second db1820s sensor - TURN RELAY D5 OFF AND STAT OFF
io(po,d5,0)
let statout = "OFF"
wait
[quit]
timer 0
wprint "<a href='/'>Menu</a>"
Any help / assistance is appreciated
Thanks
Joe
