ECOSTAT2 - With Multiple Sensors, Html, CSS, Dropdowns
Posted: Wed Sep 14, 2016 8:48 pm
Thanks to lots of help from the forum, Mike, forlotto, Electroguard, Rotohammer and others.
Here is the Ecostat2
The hardware is an ecoplug by kab which has been modified and reprogramed with a new esp8266.
The 2 DS18B20 digital thermometers provides 9-bit to 12-bit precision. Adding many more sensors is very easy.
The program provides examples on using html, centering, mark and others.
Dropdown list
All with enhanced appearance using css.
The software in general, provides the user the choice to monitor for a Toohot or Toocold condition and turn on or off a device (relay - fan etc)
The code is not pretty but works well and I invite anyone to help make it better, more features etc....
Its intent is to provide a foundation for real world examples. I hope to continue to addon features .
Maybe some buttons to call up other esp modules or udp stuff to control other slave modules
Enjoy
Joe
CSS:CODE
Dropdown list
Enjoy
Joe
'ESPBASIC V3 A42 ECOSTATcss79 SPECIAL FOR ECHOPLUG with slider DUAL TEMP
'DB1820S Temp Sensor Data PIN IS D4
'Pin D2 for led or relay output inside' forecoplug relay
'Pin D5 for led or relay output outside
memclear
cls
let tf = 0
let curr = 0
let outc = 0 'for second temp sensor
let statmode = "TOOCOLD"
setp = 19
settemp = 19
let stat = "ON"
let statout = "ON"
let setpout = 19
'cssclass "button", "background-color: #99e6e6;"
cssclass "align-self: center;"
css "test1.css"
wprint "<head>"
wprint "<meta http-equiv='refresh'content='5;URL=/input?'>"
wprint "</head>"
wprint "<body bgcolor='#527a7a'>"
wprint "<table align='center' width='102' bgcolor='lightblue' border='4' cellpadding='1'>"
wprint "<td>"
button "MODE", [NIL]
dropdown statmode, "TOOCOLD,TOOHOT"
cssid htmlid(), "background-color:#008ae6;text-align: center;display:block;width:105px"
'wprint "<br>"
wprint "</td>"
wprint "<th</th></table><br>"
wprint "<table align='center' width='170' bgcolor='LIGHTblue' border='2' cellpadding='1'>"
wprint "<td>"
button "FAN IP E79", [NIL]
cssid htmlid(), "background-color:LIGHTGREEN;text-align: center;display:block;width:170px"
wprint "<b>"
wprint "<center>"
wprint "<mark>" & htmlvar(stat) & "</mark>"
wprint "</center>"
wprint "</b>"
wprint "</td>"
wprint "<th</th></table>"
wprint "<br>"
wprint "<table align='center' width='192' bgcolor='lightblue' border='4' cellpadding='3'>"
wprint "<td>"
wprint "<center>"
wprint "Dropdown"
dropdown setp, "15,18,19,21,22,23,25,26,27,28,30,32,35,38"
wprint "</center>"
Button "<B>Trigger Level</B>",[setpt]
textbox setp
wprint "<center> Current Trigger Level </center>"
wprint "<br>"
wprint "<table align='center' width='200' bgcolor='LIGHTBLUE' border='2' cellpadding='2'>"
wprint "<td>"
button "VTEMP-C",[NIL]
cssid htmlid(), "background-color:LIGHTGREEN;text-align: center;display:block;width:150px"
wprint "<b>"
wprint "<center>"
wprint "<mark>" & htmlvar(curr) & "</mark>"
wprint "</center>"
wprint "</b>"
wprint "</td>"
wprint "<td>"
wprint "<b>"
button "VTEMP-F",[NIL]
wprint "<center>"
wprint "<mark>" & htmlvar(tfout) & "</mark>"
wprint "</center>"
wprint "</b>"
wprint "</td>"
wprint "<td>"
button "ROOM TEMP-C",[NIL]
cssid htmlid(), "background-color:LIGHTGREEN;text-align: center;display:block;width:200px"
wprint "<b>"
wprint "<center>"
wprint "<mark>" & htmlvar(outc) & "</mark>"
wprint "</center>"
wprint "</b>"
wprint "</td>"
timer 5000, [refreshcold]
wait
[on2] ' FIRST SENSOR DB1820S ---------
io(po,d2,1)
let stat = "ON"
'udpwrite "192.168.1.213", 5001, "ON" 'SEND UDP COMMAND TO SLAVE 192.168.1.213 RELAY D5 "ON"
wait
[off2] ' FIRST SENSOR DB1820S ---------
io(po,d2,0)
let stat = "OFF"
wait
[fon2] ' TEST FAN ON ----------
io(po,d2,1)
let stat = "ON"
wait
[setpt]
wprint "<head>"
wprint "<meta http-equiv='refresh' content='5;URL=/input?'>"
wprint "</head>"
wait
[refreshcold]
if statmode == "TOOHOT" then goto [refreshhot]
curr = temp(1) 'curr ' read current temperature for device 1 db1820 SECOND SENSOR
outc = temp(0) ' outc ' read current temperature for device 0 db1820 FIRST SENSOR
tf = curr * 9 ' Fahrenheit CONVERSON
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
if curr < setp then goto [on2] else goto [off2] 'FAN ON IF CURRENT TEMP < GREATER THEN SETP
wait
[refreshhot]
if statmode == "COLD" then goto [refreshhot]
tf = tf / 5
tf = tf + 32
tfout = outc * 9
tfout = tfout / 5
tfout = tfout + 32
if curr > setp then goto [on2] else goto [off2] 'FAN ON IF CURRENT TEMP < GREATER THEN SETP
wait
[outcon] ' second db1820s sensor TURN RELAY D5 ON AND STAT ON
io(po,d2,1)
let statout = "ON"
wait
[outcoff] ' second db1820s sensor - TURN RELAY D5 OFF AND STAT OFF
io(po,d2,0)
let statout = "OFF"
wait
[NIL]
wait
CSS:CODE
button, input[type="button"], input[type="submit"] {
border-top: 1px solid #96d1f8;
background: #0d51b8;
background-image: -webkit-linear-gradient(top, #0d51b8, #048f3c);
background-image: -moz-linear-gradient(top, #0d51b8, #048f3c);
background-image: -ms-linear-gradient(top, #0d51b8, #048f3c);
background-image: -o-linear-gradient(top, #0d51b8, #048f3c);
background-image: linear-gradient(to bottom, #0d51b8, #048f3c);
-webkit-border-radius: 7;
-moz-border-radius: 7;
border-radius: 7px;
text-shadow: 1px 1px 3px #666666;
cursor: pointer;
font-family: Arial;
color: #ffffff;
font-size: 20px;
padding: 10px 20px 10px 20px;
border: solid #0c3752 2px;
text-decoration: none;
button:hover {
background: #0a4980;
background-image: -webkit-linear-gradient(top, #0a4980, #d95534);
background-image: -moz-linear-gradient(top, #0a4980, #d95534);
background-image: -ms-linear-gradient(top, #0a4980, #d95534);
background-image: -o-linear-gradient(top, #0a4980, #d95534);
background-image: linear-gradient(to bottom, #0a4980, #d95534);
